Home > Faults & Fixes > ACC has a mind of its own after relocation
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Recently facelifted my range rover sport, during the process had to relocate the the ACC box to the centre use the relocation bracket,
Since doing so, i have these random cruise control msgs on the dash " set cruise 27 mph"
"Cruise cancelled", "driver intervine"
The sport goes into cruise mode after accelerating over 10mph, but then auto switches of after reaching the speed set on dash, and thats without touching any cruise control buttons what so ever.
Can anyone shed some light on this?
Much appreciated
Jay.
Post #442111 Mon Nov 10 2014 3:54pm
PEACHY
Stupid question - but I'll ask anyway Embarassed Is the sensor behind the bumper & what bracket did you use to relocate the ACC ? 16MY Estoril Blue SVR.............
Post #442117 Mon Nov 10 2014 4:48pm
flack
You need to recalibrate the ACC ecu after moving it, are you sure its level in both axis.
Flack Thumbs Up
Post #442134 Mon Nov 10 2014 7:59pm
D12TYJ
Hi Peachy, Yes its an OEM bracket which iv used during the conversion.
Thanks flack, will give this a go & see how it goes.
Quite scary driving it in this state, as the cruise control kicks in whenever it wants, & the dashboard becomes a xmas tree.
Post #442139 Mon Nov 10 2014 8:32pm
Olly-ibiza
Sounds exciting!
Post #442159 Mon Nov 10 2014 10:31pm
D12TYJ
Not having much luck with this, havnt yet had the chance to recalibrate the cruise control system.
Was wondering if its possible to disable the ACC system? Without having other related issues as i dont ever use the cruise.
Any info would be greatly appreciated
Jay.
Post #443361 Sat Nov 22 2014 9:49pm
L4FLIROP
United States 2009 Range Rover Sport Supercharged Java Black
You can disable the ACC but in order to do this you will need to edit the CCF using a suitable editor programmer. I use the Nanocom Evolution for all updates and diagnostics.
Relocating the unit was your mistake the beam pattern on these is very specific and therefor can be problematic.
Post #447077 Thu Jan 01 2015 9:04pm
