Home > Technical > engine not starting, fuel rod pressure??? :-( :-(
Tobias275
England 2008 Range Rover Sport TDV8 Autobiography Zermatt Silver
[quote="tanloverluke"]ok so good news about this problem. The LR teccie diagnosed a fuel pressure problem and that the low pressure pump wasn't working.
The garage checked it over. There was power to the pump, and funnily enough the pump now works.
They say the problem was that there was air in the fuel system, which caused the pump to stop working. And that the cause was my DRL's, which piggy backed off of the fuel pump fuse! Lesson learnt, time to look for another fuse/live ignition connection!]
not sure if this thread is still live or not but im having the same problem with my tdv8.
do you know how he got rid of the air lock and more importantly what exactly did he do for the pump to start working again?
i have power to and from the fuse and relay but the pump is not priming and there is no pressure at the schrader valve
thanks in advance
Post #593049 Thu Jan 09 2020 10:01am
