Home > General (L494) > InControl Secure - Tracker
Page 3 of 3 <123
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
They do if you live in one of the colonies for example.
Post #449759 Sun Jan 25 2015 7:08pm
dragon007
SW London?
Post #449760 Sun Jan 25 2015 7:14pm
philmw
Afraid not.
Thinking about it, as it is only keyless entry that is an option in some markets for the Sport, not keyless go, then it is not much help anyway.
Post #449763 Sun Jan 25 2015 7:22pm
dragon007
Oh well.
Well I'm sure my local dealer will have good news - NOT!
Post #449815 Mon Jan 26 2015 11:45am
philmw
I've just had confirmation that my insurers will cover my car with the CAT 6 InSecure alone, although I'm going to put a CAT 5 Tracker on too.
Maybe they are counting on the crims moving on to some other brand by the time I get my car. Rolling Eyes
Post #449955 Tue Jan 27 2015 4:23pm
dragon007
That's good.
Need to call my dealer up to discuss options.
Post #450029 Wed Jan 28 2015 7:44am
dragon007
In terms of the cat5 tracker. Are you doing this through a third party?
Post #450030 Wed Jan 28 2015 7:45am
philmw
I will probably suffer the pain and torment of buying a Tracker again as once purchased and installed they are great.
Post #450047 Wed Jan 28 2015 11:06am
dragon007
I hear that LR have a new security update.
Apparently only two keys will ever work with your car based on a 'hardware' module inside.
If you lose any key, they can't be reprogrammed - you'd need to get a new hardware module and the corresponding new keys.
I can see how this would prevent people from reprogramming keys, but I guess it doesn't prevent access to the car.
Anyone else heard of this?
Post #450169 Thu Jan 29 2015 9:00am
philmw
That's good news. The issue with access, as far as I understand it, affects any car as I beleive the scrotes either scan or block the lock code from the fob when it is used to lock the car. That's why in all the videos you see the car unlock with the indicators flashing before they get to the car. This is why double-locking using the door button is the best and safest way.
Post #450170 Thu Jan 29 2015 9:04am
Mark_N
I think that's a step in the right direction. A hardware module in the car which will only work with the two original keys. If you lose one, tough, you have to pay. A big problem requires tough solutions.
Presumably, this means it is no longer possible to program a blank key through the OBD port which has been the gaping hole in the security up to now. Third party maintainers are still catered for, you just have to buy the new module and two new keys. Wouldn't know about cost, but I can easily see a lost key could then cost £1000 but then it always was expensive in the days of mechanical keys and replacement locks.
The security only works if it is realistically impossible to replace the hardware module on someone's driveway. Otherwise, the thieves could come equipped with the module and key, do the swap and presto. Mark
SVR in Estoril Blue Thumbs Up
Post #450282 Thu Jan 29 2015 7:07pm
Page 3 of 3 <123
