Home > Maintenance & Modifications > Gearbox Flush today
cannon-fodder
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Gearbox Flush today
Hi
Just had Geoff round to do the gearbox flush and have just been out for a quick drive, as working through the SWMBO list, as I have had today of work.
The transmission fluid that came out was not too black for 97000 miles but wow, what a difference its made to the car. It is noticeably quieter with smoother gear changes. I now find the car changes gear at around 1900 rpm now instead of 2200 rpm, for the same style of driving. The car also feels more livelier and spritely to drive, with a sharper pull off from a standing start. Its made the car feel as if its got a bit more urge or younger, if that's possible.
I only had this done from what I have read on the forum, as preventative maintenance but am pleasantly surprised it has made such a noticeable difference to the driving experience.
Can recommend having this done by Geoff Thumbs Up
Post #440110 Tue Oct 21 2014 3:15pm
geoff.
am very pleased your happy Alan and yes it does make a difference Thumbs Up
Post #440123 Tue Oct 21 2014 5:32pm
Leeser23
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Geoff , can you let me know the cost please and if you come to Reading ??
Nick 2007 HSE V8, steps fitted, interior & reversing LED's, Black badges
Post #440142 Tue Oct 21 2014 7:30pm
jack.bauer
Or Essex .. 07 TDV8 + BAS map
Post #440151 Tue Oct 21 2014 7:58pm
king9750
England 2006 Range Rover Sport TDV6 Autobiography Stornoway Grey
Hi Geoff, if your still about could you let me know what the cost will be. I am in the medway / maidstone area.
Post #450641 Sun Feb 01 2015 1:08am
geoff.
will be in the chatham area on the 21st march Thumbs Up
Post #453968 Thu Feb 26 2015 8:09pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Just wondering what the thoughts are on how often to change ATF? On the service schedule the dealer gave me for my 2011 TDV6 it calls for new ATF at 9 years or 144,000miles. That seems a long time to me. When I had a Merc E320, ATF was changed at 40,000 miles then it was in for life, but I changed it every 40,000 miles. My old Freelander 2 was "sealed for Life" whatever that means, but I think it was because it was a pig to get at.
My car has 40,000 on the clock and is running as sweet as a nut and I would like to keep it that way.
Post #454009 Fri Feb 27 2015 12:14pm
Lost for Words
Now recommended at 75k by ZF. Thumbs Up Visiting from DISCO3.CO.UK
Post #454010 Fri Feb 27 2015 12:18pm
Disco_Mikey
Between 50-75k, dependant on use/towing etc
Post #454011 Fri Feb 27 2015 12:34pm
LandPhil
Thank you both for those replies.
Post #454019 Fri Feb 27 2015 2:21pm
flack
Geoff did my gearbox when I was down with him doing the Cam belt weekend and what a difference it made, highly recommended.
Flack Thumbs Up
Post #454040 Fri Feb 27 2015 6:32pm
