Home > In Car Electronics > audio spec on HSE 2007
jack.bauer
trying to figure out the exact spec on the sound system on a 2007 HSE.
looking for the number of speakers and their warrage + amp and sub specs. been searching but either not searching we
found this http://www.rangerovers.net/modelspecs/Sport/2007.html
13 speaker 12 channel 550-watt harman/kardon ® LOGIC7™ digital surround-sound audio system with 6-disc in-dash CD/MP3 changer.
which doesn't sound right since i know logic 7 was an option? 07 TDV8 + BAS map
Post #440048 Mon Oct 20 2014 8:44pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Standard audio system was 240w Harmon Kardon system & Logic 7 550w was the optional system.
If your speaker grills don't have Logic 7 badges on them, then it means you have the standard audio system. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #440049 Mon Oct 20 2014 9:16pm
jack.bauer
thanks Jas. guessing the 13 speakers are with the logic7 option?
im counting 8 speakers:
2 front + 2 tweeters (near wing mirrors)
2 rear main speakers + 2 rear tweeters (door)
+amp under driver seat
+sub (somewhere in the boot? not seen this but i have the HK setup which i know comes with a sub) 07 TDV8 + BAS map
Post #440051 Mon Oct 20 2014 9:35pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
there are more speakers in the audio system if the rear seat entertainment units are fitted
Post #440098 Tue Oct 21 2014 11:24am
jack.bauer
i dont, but that is what im looking to do
just wondering if head unit + rear screens is enough or whether to replace the amp and sub as well 07 TDV8 + BAS map
Post #440229 Wed Oct 22 2014 10:02pm
crammy
United Kingdom 2007 Range Rover Sport Supercharged Stornoway Grey
I found contradicting Info on this. Mine is a supercharged charged hse and I fo I said was 14 speaker 550 watt standard on this vehicle. I neither have the logic 7 badges but it does have the six disc changer
Post #440235 Thu Oct 23 2014 5:46am
Mark1505
Location: Wales Home, Singapore work & Also many other parts of the world,
Wales 2007 Range Rover Sport TDV8 HSE Java Black
I understand the spec in the link is in fact the USA model which I believe is slightly different spec to the UK model, with the HSE it depends also if its TDV6 or TDV8 as one has a slightly higher trim level from the other. If you check your stereo model number you will be able to find out if its the Logic 7 or just the basic HK system Java Black 2007 TDV8 HSE (my first RRS)
Colour coded door handles
Colour coded headlight washers
Smoked side repeaters
Hawk Colour coded side vents
Privacy Glass
Mud Flaps
Post #440862 Wed Oct 29 2014 5:20pm
