![]() | Home > General (L494) > 1 month in - a few thoughts and questions |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 ![]() ![]() |
Had my SE SDV6 Dynamic in Chilli Red and almond for 5 months now.
RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56 ![]() ![]() |
A good set of observations parkheat 35.
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
There are 3 levels of audio, the base one fitted to the HSE which does seem to be nothing special and then two Versions designed by Meridian though I expect made in a China. Meridian are very good at what they do and I'm surprised to hear the smaller of the two systems being labelled as c**p.
To clarify, I have the base (non-Meridian) system. Badged as a "Range Rover audio with 8 speakers (250W)". When I ordered the car, it was said to be 380W (I have the original brochure) - but this was changed down the line. At any sort of volume the speakers cannot cope, overall the system lacks bass and is very thin and 'reedy'. I suspect they use cheap cones which deform and distort. I also hate seeing/hearing speaker grilles with nothing coming out of them. My guess is that LandRover designed the car to be equipped with the lower of the two Meridian systems as standard but they needed to take cost out to achieve price points - and the audio was one area of sacrifice. I'm not moaning about it (I am the one who specced the car), but if I was ordering again, the lower Meridian system would be a tick on the options list. |
Thanks for clarifying. I agree the base audio system seems a cost saving too far. The lesser system in the Evoque (325W) could have done perfectly well as the entry level system as well. Has to be seen as an essential option I think. Mark
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
Base system is fine in my car. I only listen to the radio so not that bothered. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
