Home > General > Help needed: ridiculous rear rattle&squeak
Yanislav
Bulgaria 2008 Range Rover Sport TDV6 HSE Bonatti Grey
Hi everyone,
I have a '08 RR Sport TDV6 that a while back developed an extremely loud and thus severely annoying rattle and squeak in the rear of the car. It is a noise that is coming from the rear right of the passenger compartment for sure but unfortunately I have no clue as to its precise location. I have applyed the tailgate rattle solution just in case but as I expected it wasn't related to my problem. The rattle appears when the back end goes over high bumps, has an extremely high pitch and as far as I can tell isn't caused by the rear seats or pillars since I had a friend on mine drive around with me in the trunk pushing on every little part in hope of finding the source. It appears even when the car is completely empty-no baggage,no tools and even no roller loadspace cover.The only thing that I could find on the web that is similar is in the following video only mine is quite louder:
If you have any ideas regarding the source or possible solutions I would be deeply grateful Bow down
Post #437474 Tue Sep 23 2014 9:00am
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Could the spare wheel be loose ? or maybe the weights that hang under the back moving around ?
Post #437527 Tue Sep 23 2014 6:34pm
simple1
Get the mrs to drive it while your in the back. 👍my guess is a tired ball joint if it mimics road surface changes. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #437540 Tue Sep 23 2014 7:56pm
Yanislav
I will definitely check the spare tire because the squeak sounds like something made out of rubber that moving around, I haven't thought of that and is actually a great idea. I will also check the surrounding area and see what I can find. As soon as the weather clears I will take another ride in the trunk that's for sure. Hopefully I will have some luck this time around Wink
Post #437553 Tue Sep 23 2014 9:08pm
myfirstrrs
You could drop the spare wheel out Yanislaw and take a short trip without it hanging below the car to see if this stops it. I agree, sounds like a good thing to check.
Post #437556 Tue Sep 23 2014 9:18pm
Bodsy
Site Sponsor
Rear hub knuckle bushes are known to produce a squeak when worn.... Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #437557 Tue Sep 23 2014 9:19pm
If you drop the spare wheel and then drive without the spare in place, take care with the cable. It needs a load on it when it's wound back in or it can cause issues (there was a thread on here a while back about it). Perhaps just carefully coil it up and tie wrap it out of the way rather than winding it in. 2012 SDV6 - it's missing a couple of cylinders
Post #437560 Tue Sep 23 2014 9:33pm
Yanislav
Guys, I think I found the source !!!
In the trunk on the right side there is a small removable "door" which gives access to the locking mechanisam of the gas cap and a bunch of other wires and what not. In that area there is also a metal bracket that holds a plastic box with cables going in and out. That metal bracket is loose and as it rubs against adjacent objects it gives out that horrific noise. The solution- 2 zip ties that hold it firmly in place so it doesn't shake on bumpy roads Thumbs Up
Post #437632 Wed Sep 24 2014 4:13pm
Adrian ...
Seeing as no one else gave a thank you for that useful tip, I will. Rattles, squeaks and other noises are a Censored pain ...
Post #450298 Thu Jan 29 2015 9:16pm
Yanislav
Glad I could help Smile that noise annoyed me quite a bit for a while and hopefully no one will have to endure it in the future Smile
Post #450300 Thu Jan 29 2015 9:22pm
gogsy1956
i have the same rattle but mine appears to be from the rear left of the car. i tried most of the things you have done and you would'nt believe some of the stuff i found right in the bottom of that little "compartment ".
still not solved the rattle though Sad
Did notice that 2 of the cargo tie down brackets are missing ,,,,those chrome flip up hooky things ,, anyone know where i can get a couple as they seem to secure the basae of the boot also 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #450408 Fri Jan 30 2015 6:22pm
