Home > My Range Rover Sport > oil light flickering
cosmarks
Hi there guys,recently bought à 2009 rrs 2.7 d hse,started to notice thé oil light flickering for a couple of seconds and Also sounds à little tappity for few seconds too. Called to petrol station today,started it up and oil light stayed on a few seconds longer this time. It drives great and oil light never comes on When driving,Its dône 69000 miles,any help much appreciated
Post #437313 Sun Sep 21 2014 2:12pm
daxmatt
id stick a gauge on to check
Post #437315 Sun Sep 21 2014 2:28pm
Bodsy
Site Sponsor
Stop driving it before it goes bang!
Change the oil and filter for a genuine filter. Cheap filters can twist and crush and not long after you need a new engine, so throw £5k away for a second hand one with fitting. Don't put it off, it will be expensive if you do. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #437320 Sun Sep 21 2014 2:59pm
drdelrrs
Your motor has hydraulic tappets which should not make any noise unless oil pressure is low - they can if the car's not been used for several days but even then its not likely. A similar tappety noise can be caused by small ends.
Do you know if it has had an oil change recently and the correct oil and oil filter installed?
If you bought it recently from a dealer or trader I'd advise getting round there pronto. Fingers crossed.
Post #437321 Sun Sep 21 2014 3:02pm
cosmarks
It had à service in january,Not sure What parts were used.Any recommenced garages near sheffield to check it out,Thanks
Post #437350 Sun Sep 21 2014 7:37pm
SRE
Spain
Agree with Bodsy
The oil pressure switch threshold is very low, it could be an iffy switch, however my advice, stop driving it and get new genuine filter fitted. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #437392 Mon Sep 22 2014 9:09am
