Home > Technical > New Spec Engine Oils - Castol Edge OE 5w-30
RainHard
South Africa 2009 Range Rover Sport Supercharged Alaska White
Hi All,
just picked up some engine oil from the agents here in South Africa. With the same part number, they are now supplying Castrol Edge Professional OE 5w-30 (FST).
I had an issue as the manual says use a A3B3 oil and this is a C3. I had a look at the the link below and it seems the C3 covers all the A3B3 requirements but is the additive package good enough?
http://sas-origin.onstreammedia.com/origin...index.html
They maintain this is correct. What do you guys think?
RRS 4.2 S/C
Reinhardt
Post #437253 Sun Sep 21 2014 5:26am
When mine was recently serviced by a LR dealer in UK they used the newer oil. Looks like they are moving to one oil for all models. The C3 oil is designed to be compatible with DPF, I believe. No idea what difference it makes to non-DPF engines. I assume none. 2012 SDV6 - it's missing a couple of cylinders
Post #437264 Sun Sep 21 2014 7:53am
Disco_Mikey
C3 spec is a low ash formulation for DPF cars.
It will be fine in your car, providing it meets the other specs Thumbs Up
Post #437288 Sun Sep 21 2014 11:00am
Steviesport
Scotland 2008 Range Rover Sport TDV6 HST Stornoway Grey
Did you get your pm
Post #437294 Sun Sep 21 2014 11:09am
RainHard
Nope
Nope - not yet
Post #437308 Sun Sep 21 2014 12:30pm
