Home > General > TDV8 gone bang 70k miles |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
They happened to offer a good price for engine flush at last service and I took it ! Relief! 07 TDV8 + BAS map |
Sat Sep 13 2014 10:38am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
My service invoices have shown engine flush every time for the last three years. Both turbos went last month...
I wonder if the oil scavenger pump is marginal and so leads to the oil not been cleared from the turbos correctly...if so, the oil might be getting cooked in the return pipe reducing (and then blocking) its bore and flow leading to failing of oil seals and thus turbos. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Sep 13 2014 2:14pm |
R3JYS Member Since: 08 Sep 2014 Location: England Posts: 8 |
What mileage did yours fail at rrstdv8 ? |
Sat Sep 13 2014 5:34pm |
78k miles. 2012 SDV6 - it's missing a couple of cylinders
Sun Sep 14 2014 10:15pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
It's not about pumps or oil pick up, and milage is not a factor in failures. Mine only had 8k on the clock the first time, 48k the terminal time and had a full dealer service history having been serviced three months and 3000 miles prior to failure.
Mon Sep 15 2014 5:26am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Got both turbos off a TDV8 FFRR just now.
Mon Sep 15 2014 6:00am |
Was always careful letting mine warm up and cool down, always let it idle for 30 secs before switch off regardless of tiddling in traffic or spirited drive. Mine failed after being parked up for periods of time on each occasion so valid question. There are two trains of thought in mechanic circles, some say idling does more damage than not blah blah blah. In the case of a racing engine that is over fueling fair enough.
Mon Sep 15 2014 6:26am |
Update warranty direct have authorised full repair and I am just waiting for the car back
Wed Sep 24 2014 5:10pm |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
That's good to know well done . |
Wed Sep 24 2014 5:22pm |
ADO5TIMES Member Since: 06 Jul 2014 Location: stoke on trent Posts: 63 |
Whoa happy days. What a relief for you.
Wed Sep 24 2014 8:25pm |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
best outcome.... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Wed Sep 24 2014 8:50pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Great stuff. 2014 L405 SDV8 RR Autobiography
Wed Sep 24 2014 9:01pm |
