Home > Maintenance & Modifications > all this fuss, just for a coolant / antifreeze?
tanloverluke
so, I've been doing a few motorway miles lately and need to top up on my coolant. Local stealer is a journey away. My local texaco garage will only buy the Texaco Havoline if I take the entire box off his hands.
I came across this (quite old) post http://forum.landrovernet.com/archive/index.php/t-164726.html about OAT antifreeze, which got me reading even more posts about if it's possible to mix any and every OAT together.
Can anyone enlighten me here, must I buy Havoline or can any good quality OAT antifreeze, such as those on opieoils, be poured in?
Thanks Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #435117 Wed Sep 03 2014 6:45pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
You can put in any good qauity coolant though I keep mine the same colour.
Post #435261 Thu Sep 04 2014 6:42pm
I've used the Halfords OAT coolant - it's got the Ford approval code on it so it should be ok. 2012 SDV6 - it's missing a couple of cylinders
Post #435269 Thu Sep 04 2014 7:04pm
tanloverluke
ok thanks for that. I was wondering about the FORD spec coolant, as the owners manual refers to "WSS-M97B44". When I google this spec I find "WSS-M97B44-D", i.e with a "D" added to the end. Apparently this refers to OAT orange coolant by GM.
after reading around, I'm now 100% sure that Havoline isn't necessary. Instead it's the OAT coolant this is necessary. As for the color, apparently it doesn't need to be orange as the color is just a dye, but i'll stick with orange to match the coolant already in the system.
so yes the Halfords one is fine. but i see you get more bang for your buck at opie, who were kind to email me yesterday re: their fuchs coolant, 5-liters for 14 quid (http://www.opieoils.co.uk/p-77984-fuchs-maintain-fricofin-ll-orange-long-life-antifreeze-oat-technology-5050-premix.aspx).
thanks again guys. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #435316 Fri Sep 05 2014 10:19am
