Home > Orders (L494) > SVR Ordered! |
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 |
Has anyone noticed that when using the paddle shift and letting the car down change on its own, even when you stop it pulls away in 2nd not 1st?
Fri May 15 2015 8:10am |
It will be like waiting for delivery all over again, And falling in love all over again, and smiling like a child all over again! 2012 Evoque 2014 Sport Autobiography 2015 SVR for the fun stuff 2016 Evoque SI4 Dynamic Lux for the daily drive 2016 Defender 90 2018 SVR |
Fri May 15 2015 8:12am |
Hedders007 Member Since: 19 Mar 2015 Location: Sussex Posts: 86 |
Hi all,
Fri May 15 2015 9:30am |
When the stop/start is off, its shows a symbol on the dash - (its small, can take a picture if you want)
Fri May 15 2015 9:52am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Happy times. I think all Sports do this. In auto, the car selects first gear only if it is stationary or believes it will be stationary. You could just about feel the gear change to 1st in my old Sport when stopped. In paddle shift mode the car will try and keep the gear you select but will change down if going too slow. As the car can happily pull away in 2nd gear it will not change down to 1st. Oh, and I believe in Sport mode the car (SVR at least) will not change up in paddle mode even if you hit the rev limit. |
Fri May 15 2015 2:57pm |
Thanks Sally, So when the system is manually turned off, there is a PERMENENT reminder on the dash...... Many thanks, H. |
Fri May 15 2015 8:22pm |
Mudster Member Since: 16 May 2010 Location: Surrey Posts: 34 |
Question for all SVR owners.
Sat May 16 2015 8:38pm |
The seats are thin and hard. Ride is ok. Opinions are subjective. |
Sat May 16 2015 11:32pm |
Thanks Phil, that probably rules it out. |
Sun May 17 2015 10:15am |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 |
Same with my AB 5.0SC, again, only the case in sport mode, not sure if being in Dynamic makes a difference? 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography |
Mon May 18 2015 8:02am |
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 |
Mudster,
Mon May 18 2015 9:03pm |
Lightning Silver, not Mako I think. It is a lovely colour. |
Tue May 19 2015 6:10am |
Phil,
Tue May 19 2015 6:45am |
Fair enough - |
Tue May 19 2015 7:39am |
