![]() | Home > Technical > Engine System Fault |
bigdavy60 Member Since: 08 Aug 2014 Location: north lanarkshire Posts: 66 ![]() ![]() |
ive had a look on mine which seems to have the same fault , dont see these actuator rods tho ?, keep me posted if you find out where they are please |
crozzo Member Since: 25 Dec 2013 Location: Manchester Posts: 19 ![]() ![]() ![]() |
Have just sorted mine out with great success.
so is there only 1 turbo on the rrs at the n/s ? , i have been under the impression there were 2 ? |
On mine there is only one turbo.
hi my rrs is a 2005 2.7 diesel , have taken n/s wheel off and 1 small heat shield at top 3 x 10 mm nuts , i dont see any actuator rod so far is there anything else that needs to be removed ? cheers |
Hi mate. When I removed the small heat shields on mine, you can see the side of the turbo. There is a flat plate running across the top of the actuator. The actuator has a round ball on top. This is the piece that I moved back and forth to free it up and squirted plenty of silicone spray on it
horray at last ive found it cheers |
ooops forgot to update this post , turbo actuator freed off and both egr valves blanked , now running very well all trouble codes gone , delighted with the result |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
2.7 TDV6 have 1 turbo, 3.6 TDV8 have 2. 3.0 V6 have 2 2008 G4 RRSport TDV8 current
surprise surprise i even managed to help a fellow owner sort out his turbo actuator on his 2.7 lmfao |
