Home > Technical > Black smoke and loss of power
Higgins
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Alaska White
Hi everyone, i'm new to this forum and this is my first post.
I have a RRS TDV6 and when its at a constant speed it judders a couple of times and then the power starts to die off and occasional black smokes puffs out of the exhaust when it doing this. I have tried everything i can think of and its still the same. Has anyone had this problem or knows what it could be?
thanks
Post #433700 Tue Aug 19 2014 10:29am
Could be a split in your intercooler pipes maybe? ON THE WAY: BMW F21 M140i
Post #433701 Tue Aug 19 2014 10:33am
Higgins
checked all the pipes and no leaks, i wish it was that simple Sad
Post #433704 Tue Aug 19 2014 11:22am
EGR valve possibly. I believe the EGR functions when at constant revs / when power isn't required. If it's failing to close properly then that would cause issues with power and overfuelling (the black smoke). Have you read the fault codes? 2012 SDV6 - it's missing a couple of cylinders
Post #433705 Tue Aug 19 2014 11:29am
Higgins
It doesn't come up with a fault code which is strange, but ive read the actuals on the diagnostics and its showing both EGRs functioning correctly, but ive never had it on when the fault is happening as its difficult to say when its going to happen! it can do it as soon as you pull away or normally it will happen after 10 miles of motorway driving. suppose i should take the diagnostics out and see what the EGRs are doing when the fault is happening ??
Post #433706 Tue Aug 19 2014 11:36am
Andi
Have you tried a cleaning fuel additive?
Post #433708 Tue Aug 19 2014 12:26pm
Higgins
Yeah tried that, I'm just pulling my hair out with it now Confused
Post #433713 Tue Aug 19 2014 1:37pm
Dan Stevens
Australia 2006 Range Rover Sport TDV6 SE Zermatt Silver
i had the same problem.
a bottle of diesel injector cleaner.
i am 98% sure you will find a split in your intercooler pipe (up the top inside the 90' section) it opens up under boost.
clean the intercooler whilst the pipe is off.
An indication it is the pipe is an accumulation of oil on the bottom of the pipe.
I also did an egr delete and cleaned the "Y" section in the intake manifold.
cleaned the MAF sensor with carby clean.
new air filter.
Runs Like a dream now 245'000kms i'm at.
Sounds like a lot of work but really it's simple stuff.
Post #433745 Tue Aug 19 2014 10:53pm
