Home > In Car Electronics > Bigger Battery replaced (see pics)
customcarsuk
Hi All
Needed a new battery so after searching on the forums had some good reviews on the Bosch S5 Batteries.
So managed to pick one up from Eurocarparts cost me £133 was £160.80 but you get a Online discount if ordered Online.
The size was Huge 393mm in length compared to the old one which was only 353mm
[URL=]
[/URL]
There was No way it was going in, was just to long. In the end had to remove the plastic surrounding, Place 2 x 2x4 wood pieces to lift it as would not sit flush.
[URL=]
[/URL]
Placed the battery on top of the wood pieces, Connected it all up. Runs sweet now, Plenty of power to fire it up Thumbs Up
[URL=]
[/URL]
Post #433544 Sun Aug 17 2014 9:50pm
drdelrrs
Anybody taking bets on the life of the alternator ?
Post #433635 Mon Aug 18 2014 5:38pm
I'm struggling to see why you didn't just fit the correct size battery in the first place... 2012 SDV6 - it's missing a couple of cylinders
Post #433644 Mon Aug 18 2014 6:54pm
customcarsuk
Was struggling to find a battery the same size with a higher ah, I did a search on the forum and came up as recommended battery for the diesel 950cca
This one is bigger in size but a 920cca. was recommended one from eurocarparts when they put the registration in, the smaller one in size was a 850cca . I seen another member do the same.
I can't see it doing any damage to the alternator.
What size amp batteries are you guys running?
Post #433663 Mon Aug 18 2014 10:25pm
Mine has an LR battery in it.
You need 90Ah / 825A CCA so the original one was "big" enough for the job.
If the battery needed changing then it might be worth getting the alternator checked out (if you haven't already done so). They are a known weak issue and short journeys in the colder months might stress a weak alternator in to failing. 2012 SDV6 - it's missing a couple of cylinders
Post #433670 Mon Aug 18 2014 11:35pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Yes Landrover use Varta Batteries,90ah I had a problem with my battery,as i have more electric bits and peices ie.TV 6 DVD Player and all the usual battery draining stuff. So i upgraded to a Varta H3 Silver 100ah 830 CCA with a 5 year warranty.same size as origonal. and only £82.44 free next day delivery. Varta batteries start at standard Black,which is fitted in landrover, then Blue range then Top of range Silver. I cant see any sense in altering the battery carrier to accomadate a larger battery itisme
Post #433761 Wed Aug 20 2014 10:43am
customcarsuk
Thanks all
Can you let me know where you ordered your Varta battery from?
Looks like I will be returning this and using the original size one
Post #433787 Wed Aug 20 2014 5:16pm
A quick google threw this up, never used them, but seems to be a similar price as quoted above. Smile
http://www.battery4cars.co.uk/h3-varta-sil...ttery.html ON THE WAY: BMW F21 M140i
Post #433791 Wed Aug 20 2014 5:40pm
My 09 Plate Tdv8 still has the original battery fitted which has Varta on it and is 90Ah 950cca.
Post #433795 Wed Aug 20 2014 6:21pm
customcarsuk
Thanks Thumbs Up
Post #433808 Wed Aug 20 2014 8:17pm
harrygh60
customcarsuk wrote:
Thanks all
I got mine Varta H3 Silver 100ah from Plymouth Battery Centre £82.44 Free next day delivery Sales@plymbatt.co.uk itisme
Post #433841 Thu Aug 21 2014 8:26am
harrygh60
Agreed, but it will cost another £10 delivery Big Cry itisme
Post #433842 Thu Aug 21 2014 8:32am
