Home > General (L494) > RR Sport SVR Launched
Page 14 of 16 <123 ... 13 141516>
Mark_N
Thanks Dave, I think I'll be more than happy, especially with the roof to lighten things up. Pleased my spec is now finalised, aside from the HUD possibly becoming available to order.
All we need now is for LR to open the order book and give priority to the (I think) three of us on here with one on order... Mark
SVR in Estoril Blue Thumbs Up
Post #439761 Sat Oct 18 2014 5:22am
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Is there no possibility to have the front fog lights? Apart from practical purposes, aesthetically the front air intakes look imo better with the lights installed which break up the Cayennish grills which are a bit 'in yer face'!
Post #440450 Sat Oct 25 2014 7:10pm
Mark_N
My guess - and it is no more than that - is that the engine is on a thermal knife-edge in some environments the car will operate in but that in the UK and Europe it will hardly be a problem.
It's the same over at Porsche who frown on you installing grilles to protect the exposed radiators from flying stones, citing compromised cooling where in reality there is no problem. I can imagine in the furnace that is the Middle East, it might be, but in a baking hot Italy this summer, the water temperature in my 911 turbo didn't budge. At most, the thermostat may be in a slightly different position to compensate but there's lots of cooling capacity in reserve. I feel sure the SVR would be exactly the same.
The reason to remove them of course is to maximise the airflow through the radiators. I would certainly like to see front fogs on it and I wonder if they've gone to the lengths of modifying the column stalk to remove the switch action, removed the wiring from the loom and the legend from that stalk. If all that is still there, that might mean some retrofit is possible. Mark
Post #440453 Sat Oct 25 2014 8:22pm
peanutbob
I think you are not too wide off the mark ref the above, and I would imagine the wiring will be in place, but a different stalk. Finding an aftermarket fix might be an issue though! Maybe JLR could offer a European version with the front fogs installed...it's the only thing delaying my deposit for now, apart from hoping that I could get a swift test drive in one in the north west mainly to check how compliant the suspension set up is viz a vis my AB with 22" wheels. I have some bad memories of a year in a an Audi A6 Le Mans Estate which was pretty hard work on UK roads.
Post #440455 Sat Oct 25 2014 9:03pm
DaveW
We removed the foglights to maximise cooling and also to remove a bit more weight.
To answer your question, the lower grilles aren't designed to support fog lights and if you did go as far as to fit them, you would be reducing airflow across the coolers by 25-30% (take a look at a standard lower grille and see how big the housings are) and noting we've increased power (and therefore heat rejection) by 10%, you'd be compromising performance if we had another summer like this one past.
Also the grilles are a different shape so they might look a bit odd and you'd also degrade the frontal aspect visual of SVR by making it look like a V8SC.
X5M doesn't have front fogs either....
Its your choice to retrofit them (as it is for people to bolt all manner of things to cars) but I wouldn't advise it
And Bob, please rest assured; an Audi ride quality this most definitely isn't.
Post #440458 Sat Oct 25 2014 9:34pm
Mark_N
As regards test drives, the order book isn't open yet and we have no idea what the lead times are going to be but my hope is there will be some opportunity to test drive the car once a demonstrator is available. Call me naive, but it would be good to think there will be some sort of launch event. Mark
Post #440459 Sat Oct 25 2014 9:50pm
peanutbob
Yes...just looked at the LR config site and now I see the grills on the SVR are somewhat larger! Thanks for the reply.
Post #440463 Sat Oct 25 2014 10:13pm
Dickie
I've just had an email from my dealer who has my deposit:
"The factory have requested that we supply the contact details and SVR specifications of all the prospective sold orders.
I assume from this they will be ordering them on our behalf. There are scheduled for build Q1-2015."
I've just got to finalise spec now - not sure whether I'm going to be brave enough to go for the Estoril or not. SOLD - 15 plate Estoril SVR
SOLD - 64 plate Aleutian Silver Supercharged
SOLD - 63 plate Corris SDV6 Autobiography
Post #440503 Sun Oct 26 2014 3:16pm
Mark_N
Well, that's good news. I shall give my dealer's cage a good rattle. Decided my Evoque is too slow and too roly-poly, so time to move it on.
As for Estoril Blue, worth going and seeing the sample colour. I was rooted to the spot when I saw a similar blue (Bali?) previous gen Sport or FFRR in London. Looked great, but then I like blue cars. Mark
Post #440505 Sun Oct 26 2014 3:38pm
DaveW
So what would be your next choice of colour Dickie? To be honest, we can paint it pretty much how you want but obviously that service comes at a price....pm me if you want to know more
Post #440558 Sun Oct 26 2014 11:38pm
DBA
Macedonia
Mark, You must have considered the Porsche Macan turbo as the Evoque replacement as well.
What do you think about it as opposed to the RRS SVR?
I am kind of flip-flopping between those Smile
Post #440595 Mon Oct 27 2014 12:26pm
Mark_N
I did indeed consider the Macan turbo. I've driven a Macan S (3 litre V6 petrol) on Porsche's test track in Leipzig where the Macan is made and it runs rings around the Evoque in terms of performance and roadholding though the Macan build quality was not so far ahread of the Evoque as I expected. Porsche (or more specifically, Recarro) do their seats better than Johnson Controls, IMHO. There's not such a difference in price providing you go easy on Porsche's very long options list.
In particular, the V6 mated with their PDK is far superior to the gasping 2 litre Ford effort and I simply do not believe a car needs 9 gears unless it is very clear about which gear it wants to be in and doesn't keep changing its mind.
I have not driven a Macan turbo (though of course the 3 Macan variants all use turbo-charging) and I expect there will be a turbo S version at some point. I expect it would make a good car better still.
In the end though, it is just a sorted out next generation Q5 and like Evoques, they will be everywhere. I wanted a car which has more rarity value, more esoteric appeal, the big supercharged V8 as well as a look all its own. Make no mistake though, the SVR is coming out fully £35k more than the Porsche (£105k vs £70k), optioned up, so it needs to be good.
It will be very interesting to see the inevitable comparative reviews between the SVR and the Cayenne turbo which is its more natural competitor. As an early adopter, I have not driven an SVR so am taking it on trust it's going to be great. Mark
Post #440623 Mon Oct 27 2014 4:20pm
DBA
Macedonia
Yes, eagerly waiting for the SVR reviews since we it will be some time when we can test drive them ourselves.
Post #440703 Tue Oct 28 2014 7:47am
Mark_N
Yes, it's a gamble. We have no idea how many have been ordered and what the effect on lead times will be but here in the UK, there's a track record of starving the UK market of 5 litre SC cars because of the need to supply markets where diesels are not acceptable, most notably the U.S., and also in an effort to provide halo cars for Jaguar.
I would be surprised if there was more than one SVR a day destined for the UK market. The danger of waiting for reviews or test cars to drive is that the lead time has ballooned in the meantime. Mark
Post #440711 Tue Oct 28 2014 8:40am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Not sure how many SVRs will be built, but interestly it is not currently listed for the US.
Post #440713 Tue Oct 28 2014 9:20am
