Home > Technical > tow bar |
lesworth Member Since: 25 Jun 2014 Location: Essex / Suffolk /Cambs border Posts: 16 |
You just need the removable two bar which slips into that socket and locks with a key - on ebay for around £150. Or you can fit the heavy duty height adjustable system (looks like an oil rig hanging out the back) for more. You'll need single or twin electrics fitted and wired in to the cars systems. Electrics I think are around the same price supplied looking on ebay as well. I can't imagine it would take an auto electrician or fitting centre long to wire this in. |
Thu Jul 17 2014 10:11am |
Mr Crabtree Member Since: 10 Jun 2014 Location: Manchester Posts: 126 |
many thanks les Working with Virgin Trains and band of Brothers/Sisters to do something special for our injured servicemen and women |
Thu Jul 17 2014 10:12am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
I was quoted about £200 by a good Indy to supply and fit single electrics |
Thu Jul 17 2014 11:33am |
Gargy Member Since: 08 Jun 2014 Location: Gloucester Posts: 92 |
I've just fitted a towbar pack myself, Using the 13 pin socket.
Thu Jul 17 2014 11:56am |
Good to know Gargy - thanks. |
Thu Jul 17 2014 12:12pm |
If he's supplying the L/R OEM part, I'd let him do it for that price. In fact, I'm not sure how he can do it for that price, unless he's getting a good discount from L/R. Edit* Just read your original post concerning 'single electric's'.................. Which is probably a different harness than the twin or 13 pin socket. |
Thu Jul 17 2014 1:48pm |
Madasmad Member Since: 01 Mar 2013 Location: Crewe Posts: 37 |
The fixed tow bar is recommended if you are towing often and heavy loads. I believe the nose weight goes up from 150kg to 250kg. I bought the fixed one from Webber for £225 off Amazon. What doesn't kill you only makes you stronger!
Sun Aug 03 2014 5:16am |
stealth Member Since: 09 Jul 2014 Location: Hampshire Posts: 30 |
Blimey 250kg nose weight are you towing a tank ? |
Sat Sep 20 2014 10:33am |
