Home > In Car Electronics > Various warning lights..... ?
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Fitted the tow pack, and then towed my tin tent away for the weekend.
Firstly the cruise control came up with 'Acc blocked' on the dash, then the suspension light came on, then a warning saying the EPB had failed................... all within a 20 minute period.
Car still worked/towed ok though.
Got to our destination, switched off the car, and upon restarting everything seemed re set and ok.
We came home today without the caravan and the cruise control issue re appeared with the same fault, so we stopped and restarted the car, which re set the cruise, but after using it again, it went back into fault.
Any idea's/clue's as to what's going on ?
Not feeling confident about keeping this car if it's going to keep having constant fault's.............................
Post #430328 Sun Jul 13 2014 3:23pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Some of these gremlins come and go as a result of battery issues. I'd have the alt and battery tested to make sure that's ok before you write it off. Thumbs Up Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #430357 Sun Jul 13 2014 7:11pm
Gargy
Thanks for the tip....... I just went and tested the battery for charge using a hydrometer, and it was showing half charged.
So a good charge up has been done, and now we will have to see.............................
Post #430451 Mon Jul 14 2014 12:55pm
StrangeRover
Had this with mine last week, the problem was caused by my big foot when I pressed on the brake pedal I had caught the accelerator and obviously with cars being smart arses the mixed message through everything out . Hope your all sorted though thanks
Post #430764 Thu Jul 17 2014 2:32am
Gargy
Went to pick up the tin tent today. Set the cruise control on, and after 20 mins or so, up pops the ' ACC Blocked' message yet again. This was on the way down to the tin tent at around 70mph. After picking up the tin tent, the system had re set itself, but was soon back with 'ACC Blocked' after a few miles towing.
Anyone have any idea's what's going on ?
Or is there a way of turning off the distance sensor, and just having normal cruise control ?
It always works perfectly ok for a while after the car has been turned off and back on again...... Strange....
Post #430945 Fri Jul 18 2014 7:14pm
Disco_Mikey
The ACC part of the cruise control can be disabled in the CCF Thumbs Up
Post #430959 Fri Jul 18 2014 9:04pm
Gargy
Sorry for being a bit dim................ but 'CCF'.............. ?
Post #430960 Fri Jul 18 2014 9:41pm
Disco_Mikey
Car Configuration File Thumbs Up
Had to do exactly this on a customer's RRS. Fault code logged for a fault with the front radar, and cruise did not work at all.
Disabled the ACC part of it, and left it with just normal Cruise Control, works fine now Thumbs Up
Post #430971 Sat Jul 19 2014 6:03am
Gargy
Is this something I can do myself, or do I need the dealers diagnostic/software tools ?
Cheers for the help.
Post #430972 Sat Jul 19 2014 6:42am
Disco_Mikey
You will.need to find someone with an IIDTool or Faultmate, capable of modifying the CCF
Could always buy your own IID. Can then do it yourself, along with reading fault codes, reset service lights etc
Post #430982 Sat Jul 19 2014 10:37am
Gargy
I've just had the confirmation from the warranty people, that it has been transferred into my name from the previous owner.
Mmmmmm......... it might be worth a punt visiting the L/R dealer, and see what he says.
Post #430987 Sat Jul 19 2014 1:43pm
