![]() | Home > Technical > BT Phone |
Interested about the sat nav screen! Does Sat Nav still work properly? 2005 Zambezi TDV6 - Gone but not forgotten
nikster Member Since: 23 Jul 2006 Location: Douglas Posts: 10 ![]() ![]() ![]() |
yes it does.. i wonder if the phone kit is keeping the sat nav powered up |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Nikster, so the satnav doesn't "power up" when you put the key in the ignition? Do you get the Land Rover logo at all when you restart, or does the monitor go right back to the last screen you were on before shutting down the engine?
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Yep - my park brake light stays on for ages |
Aye, mine too. Interesting side effects though Nikster. I think it's probably a trip to the dealer for you. |
KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120 ![]() ![]() ![]() |
Bring it back. I had the BT retrofit and none of these symptoms manifested themselves. it sounds to me like they miswired something. Voice control should only sing out after you press the button. I am not so keen on the wheel mounted buttons, I suspect they stick or lock up sometimes. anyway, bring it back, they cocked it up so they should fix it RRS TDV6 (gone) RRS TDV8 HSE(gone, burned out) ML 320 CDI Airmatic |
Well it�s fixed, a well documented and know error ref bulletin no. LS417-001.
