Home > Technical > Does adaptive cruise control block speed lasers?
L4FLIROP
United States 2009 Range Rover Sport Supercharged Java Black
Re: Does adaptive cruise control block speed lasers?
wilpert wrote:
Does it block speed laser guns, if so would it still block them if the car isnt in cruise control mode?
(not that I ever drive too fast but in case somebody borrows the car and does)
You are talking about Two different Speed measurement systems.
Radar uses Radio Waves in the K, Ka, Ku and X Band
Laser Speed detection uses a laser beam which is invisible to the human eye approx 905nm.
The Adaptive Cruise Control emits a Radio signal in the 70GHz Band.
So in Short ACC Will not Jam or make you invisible from Laser or Radar Speed measurements by the Police.
Post #449922 Tue Jan 27 2015 5:34am
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Surely they use different systems to beam. The front of mine works linearly - in fact even on extreme bends it can speed the car up as the other car in front has went out of the beam. So I can't see its beam hitting a laser mounted up high.
Post #450519 Sat Jan 31 2015 11:37am
