Home > In Car Electronics > TV tuner location |
samanthacoolbeans Member Since: 24 Jun 2014 Location: nottinghamshire Posts: 7 |
oooh my first post as a new owner how exciting
Fri Jun 27 2014 3:50pm |
daveyc Member Since: 09 May 2014 Location: Liverpool / Spain Posts: 56 |
You will need to enable it in the ccf file to get it as a shortcut on screen unless you are going to use a gvif unit this works through the sat nav setting on the screen , still need to locate the original space within the rrs to see what if any wiring is there i.e. most fibre etc 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Fri Jun 27 2014 4:51pm |
