Home > Wheels & Tyres > 19" Style 1 on new HSE Dynamic
Peterlondon
United Kingdom 2010 Range Rover Sport TDV8 HSE Zermatt Silver
Does anyone know if these will fit over the brake calipers?
Post #425551 Thu May 29 2014 8:52am
Baron
They do on my RRS1 V8 and that has brembro brakes Thumbs Up  SDV8 vogue SE.
Corris grey and ivory leather + most of the toys.
Limited edition RRS model number 0001 Smile
Gone TDV8 RR Sport. Never to be forgotten.
Wife has an i8 BMW
Post #425589 Thu May 29 2014 5:48pm
Peterlondon
I can now answer my own question.
The answer is they don't fit.
Strangely the fronts can just about fit if the balance weights are moved the back edge of the wheel but the rears just won't go over the calipers.
So now the question is will 20" fit?
Post #425676 Fri May 30 2014 12:11pm
Chrisr1806
They should do. I've seen autobiographies with 20" wheels. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... Twisted Evil
Gone but not forgotten:
2014 RRS2 SDV6 HSE in Loire Blue
2011 Freelander 2 SD4 HSE in Santorini Black
Post #425692 Fri May 30 2014 2:04pm
Baron
How stupid can Landrover be Whistle
The 19" rims are perfect if you do a bit of off road and the General grabbers from ATS are cheaper and last longer.
MUPPETS  SDV8 vogue SE.
Wife has an i8 BMW
Post #425756 Fri May 30 2014 8:13pm
muddywheels
Milk Float Man
I fitted Style 1 to a MY10 3.0 TDV6 HSE and I thought the brakes were same size as Brembo Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #428092 Mon Jun 23 2014 5:04pm
Peterlondon
I can definitely confirm that the 19" style 1 wheels will not fit on the new shape RRS HSE Dynamic.
The tyre depot tried really hard, having decided the fronts would be the likely problem they changed the balance weights to ones that were in a place where they wouldn't foul the brakes and all was good, albeit with only a small margin of clearance.
They then tried to fit the wheels at the rear and they wouldn't even get close to fitting over the brake calipers.
The wheels in question has come of a HSE but not the dynamic, which must have different size discs.
Post #428144 Tue Jun 24 2014 4:48am
muddywheels
Milk Float Man
Peter your vehicle in avatar is showing MY13 but you are trying to fit them to MY14 - I wouldn't expect any of the old alloys to fit yours now Confused
Style 1 should fit MY13 as it is same as MY10 AFAIK Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #428154 Tue Jun 24 2014 7:58am
