Home > Technical > P2789 Clutch adaptative learning at its limit - 2010 RRS DV8
forumoto
United States 2009 Range Rover Sport TDV8 HSE Bonatti Grey
Hello members,
i have this 2010, with Gearbox fault message and when i scan the transfercase box module, i found P2789 Clutch adaptative learning at its limit, i will like to know what could be the culprit of this... and what re the possible causes and how can i deal with this.. i really want to get rid of the message on the panel..
secondly i do haverange rover sport vehicle lean when cornering message on panel, what can be done for this to be fix. thank you
N.B: the transfer case has a different vin in it system, could it be the reason because was from a different donor
Post #424665 Mon May 19 2014 6:02am
