![]() | Home > Maintenance & Modifications > RRS 2.7 tdv6 oil pump rattle |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 ![]() ![]() ![]() |
RAC rang back they rnt messin about recovery truck comin at 7:30 tomoz I'll go to land rover an get a filter an oil pressure switch ! I'll let you know an thank you |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
how did you get on with it |
Hi mate. You will not believe what the problem was !!!!!! We removed the oil filter an it was crushed !!!! It must of not been sat in its housing correctly when the cover was put on. We put new filter in, topped up oil, an boom fault fixed |
Quite a lot of people mess up when fitting the filters. Thank god you got it sorted. It could have ended up a real nightmare |
Urge telling me ! Deep down I really knew it had to be summat to do with oil change it was too much of a coincidence |
