Home > Technical > Coolant
JPR 1
Coolant
Keep having to top up coolant every three weeks or so. Searched for leaks with no luck and certainly no evidence on floor etc.
Any suggestions. Thumbs Up Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #424162 Tue May 13 2014 3:44pm
muddywheels
Milk Float Man
Have you noticed more smoke than normal from exhaust Question
I have seen this on older vehicles where coolant is leaking into engine - head gasket/warped piston heads - can cost a lot to repair if not dealt with quickly Big Cry
http://www.doityourself.com/stry/3-common-...nt-leaks#b
http://www.dummies.com/how-to/content/trou...leaks.html Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #424163 Tue May 13 2014 3:49pm
muddywheels
Milk Float Man
Quick search brought up some examples you could read through Thumbs Up
http://www.rrsport.co.uk/forum/search.php?...rch_time=0 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #424165 Tue May 13 2014 4:01pm
JPR 1
Thanks Muddy no excessive exhaust, will have to take to dealer I think,as no real obvious reason. Thanks again Thumbs Up Current Volvo XC90 R Design T8
Stolen 2007 TDV8.
Post #424435 Thu May 15 2014 8:02pm
mav101
i had this too.... it was apparently leaking out of the thermostat and then collecting in the undertray/evaporating... the dealer changed the header bottle to start with (a guess rather than actually searching for the leak); and it was still leaking so they had to look properly, and then found the actual cause
Post #424503 Fri May 16 2014 3:21pm
JPR 1
OK thanks Thumbs Up Current Volvo XC90 R Design T8
Stolen 2007 TDV8.
Post #424576 Sat May 17 2014 6:56pm
