![]() | Home > Technical > Electronic Rear Differential |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Nope, it's all electronically controlled and automatic. You can see it on the monitor but cannot engage or disengage it manually. Another way to visually check is to slide underneath the vehicle and look on top of the rear differential, you should see an attached actuator with wiring harness...If you don't have the rear locker, the wiring won't be there. Non locking rear diff cutout: ![]() Locking rear diff (note the additional gears and wiring): ![]() ![]() |
