Home > Maintenance & Modifications > PowerfulUKltd side steps
Taxman
Anyone purchased and fitted sidesteps to there car and does the you tube 2 part vid make sense when fitting please?
Any info would be brilliant.
Post #423152 Sat May 03 2014 8:30am
muddywheels
Milk Float Man
Can't answer your question on the side steps but I bought roof rails and bars from them and ended up getting refund because they didn't fit properly and were rubbish quality compared to LR Sad
Ady recommended some side steps a while back if you do a search or I'm sure he will be along soon Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #423153 Sat May 03 2014 8:59am
WillP
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
Re: PowerfulUKltd side steps
Will let you know next week, got mine delivered yesterday and local garage fitting them next Saturday MY2011 TDV6 HSE Privacy Glass, Sunroof, TV, sidesteps, Hawke stainless tips - Now gone
MY2015 Jaguar XE R Sport, Black Pack - Company Car
2014 BMW M5 F10 4.4 V8 Twin turbo
Post #423158 Sat May 03 2014 10:57am
Taxman
That would be great - thanks
Post #423160 Sat May 03 2014 11:02am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Fitted a set nearly 12 months ago & it was straight forward Thumbs Up I think it took me about 3 hours all in & I coated all the brackets and fittings in Waxoil to help keep any rust at bay.
Remember to set the suspension to highest position to help access
Also, a tip in keeping the aluminium strips looking good, put a thin coat of ACF50 on them monthly
Post #423163 Sat May 03 2014 11:25am
Taxman
Great - was that the pre cut sil versions from powerful?
Post #423165 Sat May 03 2014 11:38am
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Just finishing my drivers side with the step now, took me 2 hours for side one lol. I had real pain with screws at wheel, no driver would fit them, then the other side was reamed and I'm now about to go remove the screw with a fancy tool.
So I'm pleased with the quality and fit. So buy them!
Post #423166 Sat May 03 2014 11:38am
Taxman
If you can get me a pic of the finished article - if it's daylight Smile that would be brill, but I will take your advice. Thank you big time, and good luck with the otherside.
Post #423167 Sat May 03 2014 11:55am
Andy1234
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
Hi, I purchased a set from powerfuluk about three weeks ago. They were fairly easy to fit, the first side took a couple of hours but the second was a lot quicker when I knew what I was doing. They look good & I would recommend them.
Post #423170 Sat May 03 2014 2:48pm
WillP
Did they come with spare clips Andy? MY2011 TDV6 HSE Privacy Glass, Sunroof, TV, sidesteps, Hawke stainless tips - Now gone
Post #423175 Sat May 03 2014 6:12pm
Andy1234
Hi WillP, no unfortunately the set I got didn't come with any spare clips. I must admit I cracked a couple of the clips but the steps went on ok as there are quite a few clips. In hindsight I probably should of bought a few spare clips off ebay perhaps !
All in all though the steps seem good value for money.
Post #423176 Sat May 03 2014 7:23pm
WillP
Ah ok, mine didn't either! Got a local garage fitting mine so ill get some spares just in case!
They look good? MY2011 TDV6 HSE Privacy Glass, Sunroof, TV, sidesteps, Hawke stainless tips - Now gone
Post #423182 Sat May 03 2014 8:30pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Fitted them to mine about 6 months ago.
Took about 3 hours, fairly easy to do. Mine came with the pre cut cills.
Would recommend. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #423192 Sun May 04 2014 8:27am
Andy1234
Hi, yeh they look great. I am not sure how they will keep their new looks but I am going to keep them coated with a protective product as suggested elsewhere on this site. Good luck with yours I am sure you will be happy with them.
Post #423208 Sun May 04 2014 3:50pm
designboy
Just back from a trip I'll post a pic. They are very oem nothing looks off. Came with pre cut sills and new clips but the old clips were a bit more robust so I swapped them. I'd suggest a spray protection over them once done as even the oem ones rust.
Post #423318 Mon May 05 2014 9:53pm
