![]() | Home > Technical > Front brakes please help |
C11RRJ Member Since: 23 Jun 2013 Location: Northumberland Posts: 17 ![]() ![]() ![]() |
Apply some copper slip to the rear of the pads and on the ends that go in to the spring clips 👍 |
dab130283 Member Since: 08 Dec 2013 Location: Kent Posts: 16 ![]() ![]() ![]() |
Hi I have tried copper slip on both sets of pads. I have changed loads of pads in the past and never had this problem. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Britpart discs |
Hi mikey
When it comes to Britpart (affectionately known as Sh*tpart) anything is possible |
Just found a new set of brembo discs for £90.00 the pair so think that will be the best option what do you think |
As long as you can be sure they are genuine Brembo discs |
Well this is the problem they are from a motor factors on line |
£90 sounds a little on the cheap side.
Thanks for the link.
