Home > Faults & Fixes > Fault codes
Ssc11v
Scotland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Fault codes
Hi guys first post need some help
Have some codes up can anyone help
Codes are P0043,P0204,P0405
On start up low revs when pulling away lack of power
Apart from these have had owned car for last five years with no problems
RRS tdv6
Post #422022 Wed Apr 23 2014 10:15am
Hi, firstly, welcome to the site Thumbs Up
I don't know what the fault codes mean, but if i was to guess going off previous experiences, i would guess your EGR valves have packed in. I'm sure one of our more exprienced tech guys will be along soon to give you a definate answer to your fault codes.
Post #422023 Wed Apr 23 2014 10:22am
Ssc11v
Thanks have found local independent LR specialist ,although don't know any one who has used him
Would like to be able to know what repairs need done before hand
Post #422024 Wed Apr 23 2014 10:36am
A quick google says....
P0043 - HO2S Bank 1 Sen 3 Heater Circuit Low
P0204 - Injector Circuit Open Cylinder 4
P0405 - EGR Flow Sensor A Circuit Low Input
Don't know if that means anything, or is even correct, but seems to tie in with Ady's EGR reference Smile ON THE WAY: BMW F21 M140i
Post #422025 Wed Apr 23 2014 11:00am
Disco_Mikey
Your TDV6 won't have heated 02 sensors Thumbs Up
Injector faults can be ignored, unless it returns again
EGR valve failure is pretty common though Thumbs Up
Post #422088 Wed Apr 23 2014 9:01pm
Ssc11v
Cheers mike
Do you think that first two codes are there due to valve failure
Would valve failure cause lack of power that I have ?
Post #422137 Thu Apr 24 2014 1:05pm
Disco_Mikey
The first 2 codes, I would be tempted to ignore.
The TDV6 does not have heated 02 sensors, and the injector code may be a historic fault.
But, knowing how problematic EGR valves can be, it is the most logical place to start.
If the valve is stuck open, it will cause a lack of power Thumbs Up
Post #422149 Thu Apr 24 2014 4:04pm
Ssc11v
Thanks again mike
Will be booking car in next week will let you know outcome
Post #422744 Tue Apr 29 2014 3:02pm
Big rob
United Kingdom 2005 Range Rover Sport 4.4 V8 Sumatra Black
Fault code help please guys?
Hi all
Just got a RRS 2005 supercharger and today got a few codes Sad as I drive along the suspension light comes on but car still drives? But I can't raise or lower the height unless I stop and reset the car sometimes it still stays on? Today it has gone to red with max speed 30? But height is still the same? A few hours ago the lights went out but engine light came on with codes
p0320
P0441
P0333
I have no idea what this is or if it's right the only thing I did today was have a full valet of the car as I just got it which most of us do anyway, I got the codes cleared and the engine light is off but suspension light will be back I'm sure? Can anyone advise me please
Post #423875 Sat May 10 2014 7:24pm
Ssc11v
Hi guys
Have had car back from local LR specialist for few days now
Driving like a new car so pleased all lights off mpg up drastically
Two new egr valves ,full service also new brake lines ,new discs ,pads , sensors ,other bits n bobs
They kept all parts so that I could see what was done ,as car has been regularly serviced at main dealers all B services I should add , always told car was in great condition but obviously no one there has bothered to look at brakes
Never go to main dealers just a rip off
Anyway can highly recommend Monarch Garage in Glasgow
Always kept in loop about work being done and what needs done
Next job is to Polly bush front end
Post #424032 Mon May 12 2014 11:17am
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
CODE P0490
hi does any one know what P0490 code is please ?? 2007 COOLRRS
Post #431700 Sat Jul 26 2014 9:43pm
A quick Goggle suggests EGR issue. 2012 SDV6 - it's missing a couple of cylinders
Post #431702 Sat Jul 26 2014 9:50pm
