Home > Technical > front crank oil seal
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
hi has anyone ever had a problem with front crank oil seal leaking,i have fitted 2 on mine now and its still leaking am i missing something Confused silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #420960 Fri Apr 11 2014 2:17pm
Disco_Mikey
Are you pushing the seal all the way into the recess in the casing?
Post #420993 Fri Apr 11 2014 8:14pm
gazzc
pushed it in until it was flush with outer oil pump casing Bow down silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421019 Sat Apr 12 2014 7:45am
drdelrrs
Does it leak immediately which would suggest incorrect fitting or damage to the lip of the seal.
If it leaks after a few miles it might be marks on the crank. Have you checked the crank for a burr or roughness.
Post #421034 Sat Apr 12 2014 8:34am
gazzc
both times it has leaked straight away,but i was very carefull fitting it Confused silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421083 Sat Apr 12 2014 5:18pm
gazzc
Just had a thought..I had the crank hardened as advised but the crank swells when hardened would that be enough to cause a problem with the seal ..if so what would I do silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421099 Sat Apr 12 2014 9:16pm
Disco_Mikey
If the crank had swollen, it should have a tighter seal on the inner edges of the oil seal.
Post #421101 Sat Apr 12 2014 9:23pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Could there be a score on the casting that it fits into allowing oil around the outside?
Just a thought.
Regards
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #421107 Sun Apr 13 2014 2:48am
gazzc
possibly Barry,i will check everything in depth this time as i dont want to have to do it again Embarassed silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421127 Sun Apr 13 2014 8:01am
gazzc
[quote="Disco_Mikey"]If the crank had swollen, it should have a tighter seal on the inner edges of the oil seal.[/if so do you think it would swell so much that it would be damaging the seal or am i barking up the wrong tree Embarassed quote] silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421128 Sun Apr 13 2014 8:04am
drdelrrs
Do you know that the engine crankcase is not pressurising - it should have negative pressure. A quick check can be done by taking off the oil filler cap and placing the palm of your hand over it and feel if there's suction - with engine running any pressure will make seals leak - (this was a common fault on engines where the PCV valves were blocked)!
As per my earlier post I'd still suspect fitting damage to seal's lip (or, possibly, a faulty new seal). I usually wrap a crank with one strip of sellotape on the crank edge. make sure its well greased to help the seal slip into place. Obviously the sellotape is removed once the seal has slipped onto the crankshaft. (You could put silicon gasket seal on the casing to help ensure no leak from the outer edge).
(I apologise for mentioning this but you are confident you've fitted it the right way round?)
Post #421136 Sun Apr 13 2014 8:45am
gazzc
hi ,thanks for reply,think i might try the sellotape tip,yes i am fitting it the right way(i hope)i did grease it up both times and it seemed to slide on quite nicely,only thing im not to sure about is as Mikey said i pushed it flush with the casing and didnt try to get it on any further so i might try and drift it on as far as poss Embarassed silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421140 Sun Apr 13 2014 9:16am
Disco_Mikey
If you put it in as far as it will go, it will leak, as it partially blocks the drain hole. That's why I asked Wink
It should be approx 1mm proud of the front face of the casing.
They can be a bit fiddly to fit without damaging them. Lots of oil on the inside of the seals, and the shaft, and carefully push it on, making sure the seal is not being folded over as it goes on Thumbs Up
Post #421143 Sun Apr 13 2014 9:36am
gazzc
ahh you really are the voice of experiance Bow down thanks again Mike Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #421151 Sun Apr 13 2014 9:52am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi Gazz, Is this a big job? what has to be removed to access the crankshaft pully. itisme
Post #430704 Wed Jul 16 2014 9:11am
