Home > Technical > Leaking transfer box
Jonipswich
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Crying or Very sad Just had my RRS 2010 serviced at LR Colchester to be told the transfer box is leaking and will cost £650 plus vat to split, reseal and refill. Mileage 55K. Is this a common problem? Disappointing on a 4 year old car that to the best of my knowledge has only been used on the tarmac. Is the price reasonable?
Post #420095 Wed Apr 02 2014 2:44pm
Disco_Mikey
The transfer box has to be removed, and split to reseal
Post #420106 Wed Apr 02 2014 5:35pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
transfer box
might be worth getting bearings replaced as well
Post #420169 Thu Apr 03 2014 9:29am
NeilN
South Africa 2008 Range Rover Sport TDV8 HSE Atacama Sand
My 2008 TDV8 (78,000km)has just had its annual service - same story - they said the transfer box leak was so bad I should have seen oil/fluid on the garage floor. There was no evidence of a leak on my floor!! They charged R6,000 (GBP650) to replace the seals. I presume this is a fairly common problem.
Post #421737 Sat Apr 19 2014 8:55pm
