Home > Maintenance & Modifications > Remaps - Land rover detection |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
There is a flash limit built into the ECU's, but due to the way the BAS (and other tuners) work, they do not add to the flash count
Fri Mar 28 2014 5:21pm |
BBS SPY Site Sponsor Member Since: 20 Oct 2008 Location: Cyprus Posts: 30 |
In the days of the Diesel TD5 and V8 Motronic ECU's there indeed used to be an additive aspect of re programming ECU's known as a programming record that the Dealer equipment filled in and contained all the information about the data that was last programmed in, ie assembly numbers etc and the date it was programmed.
Sun Mar 30 2014 6:20pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
That's a very nice looking RRS. 2014 L405 SDV8 RR Autobiography
Sun Mar 30 2014 6:25pm |
Thanks JasM
Sun Mar 30 2014 7:08pm |
