![]() | Home > General > TDV8 Prices |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
But ............ an exrta £6k for the HST look |
Apparently you can be innocently overtaking a lorry and the ACC "sees" the lorry on your inside and jams your brakes on for you... net result = you look like a prize numpty through no fault of your own (and of course, the guy behind you has gone into your rear end). |
RRS-NL Member Since: 14 Jun 2006 Location: The Netherlands Posts: 151 ![]() ![]() |
The TDV8 specs are presented in Holland for the RRS.
Ecowarrior Member Since: 16 Aug 2006 Location: idiotsville Posts: 34 ![]() ![]() ![]() |
following on from Country Bumkin and getting this thread back on course.
The MY2007 RRS interior!! |
RRS-NL tHEN YOU ARE IN FACT QUITE SAD!! |
???? Sorry, did I miss something? Please explain ![]()
When I look at the pictures of the TDV8, it looks like it's getting the Supercharged grille ![]() |
The new wood does look better |
Does look a bit nicer - is this the so-called American Walnut or whatever it was?
Had this dream..somebody was drooling over the plastic wood effect trim in the 2007 MY!!!....how sad can you be?.... |
Country Bumkin Member Since: 22 Aug 2006 Location: in them there fields Posts: 21 ![]() ![]() ![]() |
Plastic wood or not, one benefit of the HST is that the exclusive hand polished wood trim means that wannabees will be unable to chav their cars up to look like something there not. |
Bumkin,
Ecowarrior.
You have to be joking!!!
