Home > In Car Electronics > What's this cable?
redranger
Canada 2008 Range Rover Sport TDV8 HSE Rimini Red
What's this cable?
Hi everyone,
I had took apart my center console unit from the radio back to the cooler unit on my 08 RRS.
I came across the following cable just sitting there. Anyone know what this is for? As well does anyone know
What the following plugs are for on the back of the navigation head unit?
Wondering if there are some options such as rear view camera or ipohconnector that iI can add on.
Post #418626 Fri Mar 21 2014 12:43am
mse
look either like part of the can bus network or the cameras Mike
2014 Facelift Discovery
Post #418891 Sun Mar 23 2014 3:16pm
canamrotax
Canada 2006 Range Rover Sport 4.4 V8 HSE Java Black
The pink cable is most likely Sat Radio. Modern SAT radios do not use the locking portion anymore, so it is possible to remove the pink section and plug in an XM or Sirius radio. The ports on the back of the OEM NAV screen are for TV and cameras, but are in PAL format, not NTSC. I looked into NTSC to PAL converters, and decided I can buy a whole aftermarket system for that.
Plus the resolution of the stock screen is crap. "There's always a bigger fish"
Qui Gon Jinn, Star Wars Episode 1
Post #423331 Tue May 06 2014 1:50am
