Home > In Car Electronics > Sat Nav question |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
Maybe its trying to tell you that Windsor is where you should actually be. Have you thought about drawing up a list of pros and cons for Cobham v Windsor???
Tue Mar 04 2014 5:26pm |
MalibuRocks2 Member Since: 04 Mar 2014 Location: cobham Posts: 6 |
ha ha was driving to work this morning ,looked at the sat nav ,had me at heaathrow.
Tue Mar 04 2014 5:31pm |
cobbler2u Member Since: 09 May 2010 Location: hertfordshire Posts: 69 |
got the same problem. its also says no gps.
Thu Mar 06 2014 6:58pm |
exactly the same ,checked disc,GPS sign is crossed out |
Thu Mar 06 2014 7:16pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Read something similar on the D3 site, a fault on the roof aerials one of the regulars was showing a fix but carn't find it now !! 2008 G4 RRSport TDV8 current
Fri Mar 07 2014 1:40pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Check out cheap fix for gps aerial. go to search and put in gps then read thread from flack. I have same problem bought the bit from ebay just waiting to fit.
Fri Mar 07 2014 2:27pm |
Cheers Panda ,much appreciated ,looks like this could be it
Fri Mar 07 2014 3:19pm |
Fri Mar 07 2014 3:27pm |
