![]() | Home > Orders (L494) > Off-Road - On-Road/Off-Road pack? |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Problem is, in the UK at least, these packs do not exist, I assume they are option bundles. Mark
malcolmw Member Since: 05 Dec 2013 Location: United Kingdom Posts: 122 ![]() ![]() |
Well, they certainly did last August when I placed my order for a HSE. I went for the off-road only option as I didn't feel the Dynamic Drive was worth it after my test drive and, after all, it is a Range Rover and should have maximum off road capability. Regards
Baco Member Since: 13 Aug 2013 Location: Belgium Posts: 154 ![]() ![]() |
Ouch, I see. And I though you guys were all shy |
My mistake, they do exist but are only available for the HSE, standard for higher models, not available for what was the SE. Mark
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
I went for a HSE Dynamic because it came with a Hi/Lo ratio box as standard.
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Just ordered yesterday French spec: SDV6 AB Dynamic .....
