Home > Maintenance & Modifications > More help needed plz, multiple faults on dash :-(
TaddyHST
England 2008 Range Rover Sport TDV8 HST Java Black
First off id like to say thanks to everyone for all the great advice I've had on other issues ur all brill!
BUT lol I still need advice again Sad
Car had a service last week no bother but on the way home a few errors came up on the dash (suspension fault, HDC Fault, transmission fault) all the usual gd stuff so did some research on here and decided to swop the battery which cured it for all of two days now there all back but with some bizarre noises before startup also. The car did have a new brake light whilst in for the service which I've read can cause many of issue but as this has been done the only thing that I can think is left to change is the brake switch but would this also cause the funny noises and also putting itself into lower height mode?
Getting very fed up with it now
Thanks in advance for any help
Simon Simon AKA TADDY
58 plate RRS TDV8 HST - 22" onyx wheels, revere lights and colour coding Very Happy
Post #415765 Thu Feb 27 2014 1:22pm
rigsby
Was it a genuine bulb they used? Some bulbs even when working cause dash warning lights to come on MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #415832 Thu Feb 27 2014 5:40pm
TaddyHST
Hi mate thanks for the reply, wasn't sure what they used so I've swopped both brake bulbs out for Bosch ones on my way home tonite faults still there but getting the ecu reset tomorrow at garage and diognostics done also so fingers crossed. Simon AKA TADDY
Post #415851 Thu Feb 27 2014 7:13pm
TaddyHST
Hey guys I've now swoped the brake switch also and all faults are still there with car still stuck in access height as well even though it drives as normal just really low. Any advice? Plz? Lol Simon AKA TADDY
Post #416735 Wed Mar 05 2014 7:24pm
PEACHY
Forgive me if I'm covering old ground - have you tried putting it into extended mode - raise the suspension then lowering - does it work as it should ??? Where is the strange noise coming from - not on the passenger side in front of rear wheel Crying or Very sad 16MY Estoril Blue SVR.............
Post #416737 Wed Mar 05 2014 7:37pm
TaddyHST
No car doesn't raise n lower and the noise seems to come from under the centre of the car Simon AKA TADDY
Post #416739 Wed Mar 05 2014 7:43pm
PEACHY
Is it a vibrating noise ? - does it make the noise without the engine being turned over ? 16MY Estoril Blue SVR.............
Post #416743 Wed Mar 05 2014 7:55pm
RRSSTEVE
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
SOUNDS TO ME LIKE SOME NUMPTY TECHNICIAN JACKED YOUR CAR UP ON THE SUSPENSION COMPRESSOR BREAKING THE MOUNT AND KILLING THE AIR SUSPENSION PIPES.
Post #416749 Wed Mar 05 2014 8:39pm
TaddyHST
It's more like an electric ticking noise if it wasn't for all the fault lights Ide think compressor but they came up shortly before the car locking in access height Crying or Very sad Simon AKA TADDY
Post #416752 Wed Mar 05 2014 8:52pm
martyn05
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
Hi mate, where did you get your car serviced?
I see your in the Mansfield area, I am by Junc 25 and use a independent LR garage at Wirksworth, they seem to know there stuff 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #416757 Wed Mar 05 2014 9:00pm
TaddyHST
Cheers matey I may give them a buz tomorrow. I used Trd performance at hucknal used him for a few years now on previous cars with no bother. I've just took a quick vid of the noise will upload shortly Simon AKA TADDY
Post #416760 Wed Mar 05 2014 9:12pm
martyn05
You need someone who deals with RRS all the time.
Speak to Nick at DLS, I questioned him on a few things and he seemed to be well informed and knowledgeable.
I just had tow electrics fitted there last week.
http://www.dls-uk.co.uk 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #416764 Wed Mar 05 2014 9:21pm
TaddyHST
Great stuff cheers mate ile give him a call tomorrow, really appreciate it Thumbs Up
Here's a vid of the noise
http://s628.photobucket.com/albums/uu4/tad...ba08cb.mp4
Thanks for the help guys Simon AKA TADDY
Post #416780 Wed Mar 05 2014 10:05pm
drdelrrs
Loose
- heat shield,
- compressor bracket,
- exhaust bracket ?
Post #416802 Thu Mar 06 2014 8:56am
martyn05
Did you speak to Nick? Any joy ?? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #416847 Thu Mar 06 2014 5:53pm
