Home > Maintenance & Modifications > Remap advice
Chrale
Remap advice
Just out of curiosity, does it make any difference other than a bit more responsive and gets rid of flat spot pulling away?
I ask as the RRS only really gets used by the Mrs to transport jnr and the dog about, mainly city centre driving. Only really gets to stretch its legs if i use it. Is it beneficial if its just used for this type of driving? Car has full history, belts just been done and kept in A1 condition due to having Mrs, jnr and dog in it. I've always been a bit sceptical of remaps causing issues to cars.
Im guessing theres no horror stories with remaps?
its a TDV6.
Thanks
Chris 2007 TDV6 HSE
Post #415370 Mon Feb 24 2014 9:50pm
You'd probably be better using the money to run it on the high-spec diesels (Shell Nitro, BP Ultimate etc.). Town driving/short hops isn't great for engines and using decent fuel should help keep everything clean and in better condition. 2012 SDV6 - it's missing a couple of cylinders
Post #415381 Mon Feb 24 2014 11:32pm
StrangeRover
How does the warranty stand if you remap the ecu... Thinking about this on my RRS tdv6
Post #415692 Wed Feb 26 2014 11:16pm
Unless you have specific agreement from the warranty provider then they will run a mile from any claim that they can pin on the remap. Provided they figure out / can prove that it has a remap of course. 2012 SDV6 - it's missing a couple of cylinders
Post #415696 Wed Feb 26 2014 11:45pm
StrangeRover
Think I might have to wait a bit then as I have main dealer warranty . I'm sure they would spot it a mile off
Thanks
Post #415699 Wed Feb 26 2014 11:51pm
Depends on the remap. Some (like site sponsor BAS) have a device that lets you change the map back to standard whenever you like. This is useful when you take it in for a service etc. You then put the performance map back on when you get home. 2012 SDV6 - it's missing a couple of cylinders
Post #415701 Thu Feb 27 2014 12:01am
StrangeRover
Would you recommend bas ? Sounds like the sort of remap I would need
Thanks
Post #415702 Thu Feb 27 2014 12:05am
