Home > General > suspension red light then... |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Could be the Air Suspension Compressor - did you have any previous warning lights appear - these would be yellow advising ride height only & showing a symbol of the car with arrows above it.Was the compressor noisy - it lives in front of the passenger rear wheel.If it is the compressor I've never known the failure to cause punctures or total failure without warning. are all the other wheels at normal height ? what messages if any do you get when your try staring the RRS 16MY Estoril Blue SVR.............
Sun Feb 09 2014 9:25am |
onethumb Member Since: 09 Apr 2013 Location: wolves Posts: 30 |
Hi PEACHY, no warning lights before, no extra noise, yes two front wheels are normal height, just started it up and there was no message the dial was saying it was at max ride height so turned the dial and pump started now its back to normal. This is more worrying. more help I think. RRS 2006 supercharged
Sun Feb 09 2014 9:46am |
Could it have been the puncture FIRST not the EAS failure ? that would make a lot more sense 16MY Estoril Blue SVR.............
Sun Feb 09 2014 9:49am |
Hi PEACHY, thanks for your reply, Would that cause the both sides to drop all that way down?
Sun Feb 09 2014 9:59am |
who knows - our cars have a mind of there own Disco Mikey / Flack or Bodsy might give you a bit more info if they pick up this thread later. Happy days if its just a puncture still a pain but it could have been worse. Get it repaired & see how you go - proceed with caution. Spend a few minutes lowering & raising the suspension just to make sure its working fine. 16MY Estoril Blue SVR.............
Sun Feb 09 2014 10:09am |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
it would if debris or something has punctured/snapped the suspension pipe work as both sides are linked together on the rear, when i had a leak both sides dropped, but the leak was on nsr |
Sun Feb 09 2014 3:51pm |
update:
Sun Feb 09 2014 4:06pm |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
I dont want to swap wheels but i am really pleased you got it sorted mate |
Sun Feb 09 2014 4:14pm |
These must be local to you http://www.equicar.co.uk/breakers/breaking...2=Go+-+%3E no harm trying 16MY Estoril Blue SVR.............
Sun Feb 09 2014 5:13pm |
thanks PEACHY, will call them in the week, I've used them before, they are not cheap but they do have good stock RRS 2006 supercharged
Sun Feb 09 2014 5:24pm |
Update, today got two new tyres fitted as didn't know if the other rear had been run flat either so to get rid of any doubts and due to comments about same tyres on axels, thought better safe and have less money than sorry.
Wed Feb 12 2014 1:20pm |
By the way the other tyre was fine so didn't need to replace RRS 2006 supercharged
Wed Feb 12 2014 1:21pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
our sc cars come with the black 19 as a standard spare wheel. Hope you get ot sorted. Keep us posted. |
Wed Feb 12 2014 1:51pm |
