Home > Wheels & Tyres > Help!!! 20" that don't fit over brembos...
bl74beano
Australia 2007 Range Rover Sport TDV8 SE Atacama Sand
Hi All,
I know this has been done to death but just got a set of 20" genuine RR alloys shipped from the other side of Aus and they didn't fit (was sent the wrong ones 58mm offset not 53mm) I just want to double check before I send them back and order new ones that they will fit over the brembos... has anyone put this style over the brembos???
Help much appreciated... already cost $1400 in temp replacements and don't really want to spend another $500 in postage back and forth...
Edit- 2007 so bigger brembos than 2010 on?
[/img]
Post #413040 Fri Feb 07 2014 11:15pm
bl74beano
if not has anyone put these over brembos?
All 53mm offset...
Post #413041 Fri Feb 07 2014 11:18pm
Disco_Mikey
Are you sure they are genuine, and not replicas? Sounds like they are for an 02-05 FFRR. I had the same issue with mine, and had to sell them on again, and buy another set. Mine were replicas BTW Sad
All Brembo calipers are the same size between RRS/FFRR
Post #413044 Sat Feb 08 2014 12:24am
fkarim
I put these genuine wheels over Brembos on my previous RRS (2009) without any problems but I don't know what the offset was.
Post #413047 Sat Feb 08 2014 12:29am
bl74beano
Real for sure they were still in the boxes, everything tickity Boo, but they were 58mm offset (there are 2 variants of this style it would appear) and I was told the 53mm was the one I needed. They are actually FFRR Vogue wheels. Apparently even if they have the same brembos the offset is different (the brembos are also different post 2010, which may be the issue here...)
Post #413063 Sat Feb 08 2014 9:13am
bl74beano
Cheers Fkarim... these are the ones I'm least keen on but may end up going with them just to be safe ... good to have at least one confirmed as good (these are actually a RRS wheel so I was fairly sure they'd be good)..
Post #413064 Sat Feb 08 2014 9:16am
