![]() | Home > General (L494) > Front brake discs damaged on the inside? |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 ![]() ![]() ![]() |
When you look through the wheel spokes you see the outside face of the disc, so the inside face is not visible unless you crawl underneath.. Do another 2000 kms and the score will more than likely have disappeared.. 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Sounds very odd to me and I agree, limited scoring of the disc is unlikely to be a problem. If you are minded to, crawl under the car with a torch or try to get a look at the back of a brake disc with a mirror.
somchie Member Since: 19 Jan 2014 Location: Where it always rains Posts: 36 ![]() ![]() ![]() |
Well... Land Rover informed me today they will replace the front brake discs on warranty.
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Excellent result |
