Home > Faults & Fixes > Alarm keeps going off
sonnyjim
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
This is getting rather annoying now, alarm will go off within an hour of leaving the car. I have checked all doors, tailgate and bonnet and all seems ok.
2006 RR Sport supercharged.
Any ideas before I take it to get looked at
cheers guys
Post #411662 Wed Jan 29 2014 7:14pm
stevew
United Kingdom 2009 Range Rover Sport Supercharged Zermatt Silver
I had this on my 2007 sport and the sensor on the bonnet was faulty, I was told it was a common problem
Post #411767 Thu Jan 30 2014 8:23am
mav101
yep, same here. Faulty bonnet catch...
Post #411849 Thu Jan 30 2014 3:49pm
sonnyjim
Ok funnily I did actually search and thats what came up...I looked under the bonnet and could not for the life of my find the sensor... where is it located and is it an easy job to swap out/DIY fix?
Any cost on the part?
Post #411865 Thu Jan 30 2014 5:47pm
Should help you locate it Smile
Quick search says they are not expensive at all Thumbs Up ON THE WAY: BMW F21 M140i
Post #411866 Thu Jan 30 2014 5:58pm
sonnyjim
Cheers will give it a go...
Post #411867 Thu Jan 30 2014 6:03pm
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
Just replaced mine, 5 minute job.
Remove the two torx bolt that fix the drivers side (UK) or passenger side (US) to the front panel, lift up the hood/bonnet latch and you'll see an electrical connection. Unplug the connection then remove the alarm sensor from the latch.
The alarm sensor just slides onto the latch with two plastic clips holding it.
I removed the front grill so I could be sure that the hood/bonnet lock was striking the latch right in the middle.
(Don't ask me how I know that if they're not aligned you have a chance of the hood/bonnet release not releasing the hood/bonnet.....)
Slide the new one in, attach the electrical connector, align the latch with the hood/bonnet lock and tighten it up.
I locked the latches with a screwdriver before attempting to close the hood/bonnet and made sure the hood/bonnet release lever activated the latch. Then I closed the hood.
Post #430284 Sat Jul 12 2014 9:37pm
RRS Daz
Yep mine was bonnet catch too.
Always went off in the middle of the night and never during the day too?!?!?
Post #430293 Sun Jul 13 2014 8:06am
Sledge
England 2006 Range Rover Sport 4.4 V8 HSE Bali Blue
Same problem with mine just managed to get the part so will be fitting it later will be nice for the rest of the street to get some sleep without my alarm going off!
Post #430830 Thu Jul 17 2014 6:49pm
Sledge
Yep replaced the hinge & sensor came as one & all sorted, easy cheap fix.
Post #431183 Mon Jul 21 2014 7:21pm
OdinN
Sledge,
My neighbours are also delighted that I found this thread. WD40 has worked on mine (so far) but I'd like to also be ready to replace the sensor / hinge if required. Can you tell me where you sourced yours from and/or the part no? I couldn't find it in the other threads. Ta.
Post #431184 Mon Jul 21 2014 7:31pm
Sledge
Got the genuine land rover part from a parts place in Luton don't know the part number as I have thrown the box away but its the drivers side bonnet catch with sensor, came as one part £26 including VAT so pretty good & 5 mins to fit.
Post #431274 Tue Jul 22 2014 5:48pm
OdinN
Thanks. So far WD40 has done the job but at that price I reckon I'll buy the part just in case!
Post #431320 Wed Jul 23 2014 5:18am
scottheasman
Hi guys, I have got this problem and the alarm is driving me crazy what sensor am I looking for? Just so I can get the part as the car is going in to main dealer tomorrow? Thanks
Post #433026 Tue Aug 12 2014 6:26pm
Sledge
It is the drivers side bonnet sensor that comes attached to the bonnet catch.
Post #433048 Tue Aug 12 2014 9:20pm
