Home > Technical > Calibrated suspension but dash display shows differently
Eballs28
United Kingdom 2006 Range Rover Sport TDV6 HSE Giverney Green
I've got a 06 TDV6 HSE and had a few problems with my suspension in that it didn't feel right whilst driving. It felt like you were always moving the steering wheel as if the car was pulling to the left, and you were correcting it, but the car wasn't pulling to the left. It was just giving that impression.
So I set about looking at the calibration settings of my suspension.
I measured the height on level ground from centre of the wheel to the arch and the front was 450 both sides and the rear was 457 on the right and 450 on the left.
I used my Nanocom and got the car level all round and wrote the readings. I now have 460 on both fronts and 465 on both rears. The car now drives perfectly BUT the touch screen display shows all wheels being different heights.
Prior to calibrating the suspension the touch screen showed both front wheels perfectly level and the rear wheels ever so slightly out.
Am I doing something wrong or do I need to replace the height sensors?
Post #410602 Tue Jan 21 2014 11:44pm
