Home > Maintenance & Modifications > How to fit a new instrument dial cluster set RRS 2005-2009
Grimps42
England 2005 Range Rover Sport Supercharged HSE Rimini Red
Hi
I am thinking of changing my RRS 2005-2009 instrument dial set with a newer looking after market coloured display has anybody done this, if so how difficult is it to change?
What's involved and how long would it roughly take?
I have seen some posts which looked like you need to take half the drivers side including steering column facia and electrical connectors away? In order to remove the dial set assembly?
Any advice would be greatly appreciated
Post #410402 Mon Jan 20 2014 9:37pm
Kensta
Grimps did u get any joy with info doing this job?im lukin at doing mine aswel soon I've already got the clocks Java black 2006
Post #410435 Tue Jan 21 2014 6:38am
Grimps42
No replies as yet but will let u know if someone responds
Post #410437 Tue Jan 21 2014 7:21am
flack
Where is the after market one.. Also the Ipack contains the CCF file which tells the car what configuration's it set to, You might also have problems with mileage settings. All your ECU's are sync to the Ipack so it knows what connected in the car.
Flack Thumbs Up
Post #410440 Tue Jan 21 2014 8:14am
Grimps42
Sorry Flack all I am after is changing the dial set to an after market type maybe a plasma illuminated one, rather than the OEM one on the car.
Post #410494 Tue Jan 21 2014 5:13pm
Kensta
Same here, I have the overfinch replacement white dials Java black 2006
Post #410497 Tue Jan 21 2014 5:22pm
