![]() | Home > Orders (L494) > RRS petrol V6 Supercharged in Europe |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1674 ![]() ![]() ![]() |
There is no petrol V6 supercharged (as far as I know). |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Yes there is, just not available in the UK.
Interesting. I knew they've launched one for the FF.
Assume it'll be this one that they say you can get in the FFRR |
Just found it - Australian market for the RRS - https://newrangeroversport.landrover.com/au/en/#explore/overview |
embar76 Member Since: 05 Mar 2012 Location: Poland Posts: 7 ![]() ![]() ![]() |
I met up with the opinion that the supercharged V6 is the successor to the old V8 without recharging.
The V6 is used in the Jaguar F-Type in two states of tune and an even hotter version of the V8 is used there as well which presumably will be the basis of the expected RRS RS.
Yes, the RS will probably use the 550 hp V8 from the XJR/XKRS/F-R.
viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857 ![]() ![]() ![]() |
4 cylinder Hotfire engine is also going into the f-type so local dealer says 2016 bmw x5 40d m-sport space grey
Yes, I read the 4 cylinders are going to be the first engines made in Wolverhampton, so the Evoque and Freelander will be the first plus the Defender replacement.
