Home > Off Topic > M1 to 60MPH |
Looks like they are considering putting a section of the M1 to 60, mainly for emissions
Mon Jan 06 2014 11:33am |
I totally agree. There are plenty of other examples of good roads network and designs, like: the USA right turn on red, Germany autobahns, most European roads approach to incidents etc
Mon Jan 06 2014 1:00pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Reducing speed does increase capacity (within limits of course). It will also reduce emissions quite obviously. It would seem likely that this temporary measure is the first stage of a general cut in speed limits (with associated tax raising, sorry I mean safety cameras).
Mon Jan 06 2014 1:08pm |
I would argue the emissions point, although only from the stance that its a relative cut eg: a car designed to do X emissions at 70 will do less by driving slower in theory because of less revs...equally put it in 5th from 8th, revs increase and emissions (overall )don't change...but most cars are now designed with emissions in mind anyway. A good friend also makes some valid arguments about emissions linked to fuel use, which again makes the point of speed and MOT type emissions test difficult to explain (he works in the automotive industry and as I cant explain as well as he, im not going to try)
Mon Jan 06 2014 1:37pm |
The chances of doing much more than 60 on that stretch is confined to the early hours.
Mon Jan 06 2014 1:45pm |
The planning for road trains needs to start now if we are to be in a position to implement them in a reasonable time scale. For a start, the vehicles themselves need to have the facility built in. No reason why the sort of systems (active cruise with queue assist is effectively a stand alone part of a road train) seen in upper sector vehicles can't be made main stream over the next ten years. 2012 SDV6 - it's missing a couple of cylinders
Mon Jan 06 2014 1:51pm |
Mike, if you reduce speed then you reduce fuel usage (within limits). If you reduce fuel usage then you reduce emissions (again, within limits).
Mon Jan 06 2014 2:09pm |
Im sorry, maybe there is a miss understanding...but reducing speed, doesn't reduce fuel usage and thus reduce emissions - at least not as simply as its made out. Firstly I will point out that, I did say there could be a relative decrease in emissions, but that actually there were other factors. For example
Mon Jan 06 2014 3:23pm |
Some cars might be geared to give max economy at 70mph but I bet many aren't. The EU fuel consumption test has a max speed of 75mph but averages at about 40mph in the extra urban test. So getting good economy at speeds lower than 70mph is likely to give better EU fuel figures - and that is important for the manufacturers.
Mon Jan 06 2014 9:33pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
Had anyone done a real time fuel economy test in the sport?
Mon Jan 06 2014 10:03pm |
One other problem with this totally irrational scheme that nobody not even the media have highlighted is that all car speedometers are deliberately designed to over-read; many by as much as 15%. This means that lots of muppets will be driving at 51mph thinking they are doing 60.
Tue Jan 07 2014 6:13pm |
There is an error - but I wouldn't rely on that too much, the error on a new sport is only a few MPH, older sports might be more for sure. GPS isn't perfectly accurate either...but your point is also correct Mike
Tue Jan 07 2014 7:55pm |
At 30 mph showing on my dash, my road angel is showing 27 mph. At 70 mph on dash my road angel is showing 66 mph. My road angel is the correct speed and the one that i go by at all times. Its surprising how may cars i follow in a 30 mph zone and the car in front is only doing 26-27 mph. (20" wheels by the way) On 22's the cars speedo was a little more accurate with the road angel. This polution argument is a load of , no matter how many lanes there are, there will be still the same number of vehicles passing through, its just that they will all be going through 10 mph slower causing congestion further back down the motorway at peak times as the faster traffic catches up with the traffic doing 60. Its always the same when traffic is forced to slow down increasing the chances of a collision. |
Tue Jan 07 2014 10:05pm |
Glad to hear it. 30mph zones tend to be places where the locals actively try to kill themselves under your wheels. Driving a bit slower might just foil their suicidal plans and protect your paintwork. If you follow me through a 30mph limit you'll generally find me travelling at less than 30mph too. On national limit roads, you'll usually need to be going a bit more than 60mph to stay with me... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Jan 07 2014 10:10pm |
