Home > General (L494) > Max fan speed |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
please donīt let that be true.....
Mon Jan 06 2014 12:07am |
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 |
On our old Disco the max demist / windscreen button was very good for the condition you mention. Yes it auto selected which vents it used but that is for reason. Give it a try mate. |
Mon Jan 06 2014 6:53pm |
If you leave the temp set to Auto then it will still do what it thinks you need, if you want max heat try to wind the temp up manually as well. |
Mon Jan 06 2014 6:54pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Hi Disco
Mon Jan 06 2014 7:51pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Select the vents too? |
Mon Jan 06 2014 8:01pm |
All vents open front and rear! Going from auto to max fan speed increases the output very slightly. No great whoosh of air! |
Mon Jan 06 2014 8:08pm |
What if the auto function was calling for max anyway? It would not turn up any more.
Mon Jan 06 2014 8:12pm |
Ahead of you on that one! I thought of that over the weekend. On auto there is a steady trickle of air, which has been the same since October, hit max fan and there's slightly more air but not a lot
Mon Jan 06 2014 8:20pm |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
Have you turned auto climate off before turning fan to max? 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
Tue Jan 07 2014 9:31pm |
