![]() | Home > Faults & Fixes > Front grinding after going through huge puddle at speed |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Good find. Sometimes, if the bearing is hot it will "suck" cold water into the hot bearing (boat trailers are a good example)
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 ![]() ![]() ![]() |
Hi, Happy New Year to you all.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Timing belts are a doddle to do, and if your 06MY profile is correct, blank your EGR valves |
