Home > Technical > GAP Diagnostic– new products / update announcement 12/2013
Page 3 of 4 <1234>
idrabble
Australia
PatGapInnov wrote:
(will be available for non BT units shortly)
Any update on the timeline for this? I want Nav on the move Very Happy
Thanks, Ian
Post #429283 Fri Jul 04 2014 5:06am
Disco_Mikey
Nav on the move is currently undergoing beta testing Thumbs Up
Post #429284 Fri Jul 04 2014 5:50am
PatGapInnov
Canada
Hi Guys
For those who have been waiting, the time has finally come. Very Happy We've now released V3.0 for regular non Bluetooth IIDTool's made for Range Rover Sport and Discovery 3/LR3 up to 2009. We will send an e-mail to each user on Monday but for now, you can have access to it using the updater software (may need to be updated depending on which version you are using).
The following new features are included in V3.0 for non Bluetooth IIDTool’s:
• Supports the new PC based interface
• Additional calibration functions (steering angle, transfer box)
• ECU Re-flashing (Bluetooth, Nav On Move, modified IPC Instrument Pack with FBH light fix all added)
• New VIN lock policy:
Standard diagnostic functions (free of charge on any L319 or L320 up to 2009)
• Fault read / clear
• Live values
• Control outputs
• Service / test functions
Enhanced diagnostic functions (one free VIN, extra VINs are available from your Britpart dealer at around 60 GBP):
• ECU Re-flash
• Component and system calibration (steering angle sensor calibration etc)
• Advanced functions including backup / restore, save profiles – vehicle system settings and
configurations are read and stored as a backup file for a restore function, various changes
to systems (e.g. suspension height) can be stored and changed quickly
The user manual is also available for downloading. We strongly suggest reading it before using this new version, especially if you want to perform the new re-flashes.
As always, your feedback is much appreciated.
Thank you for your support and patience!
Cheers Thumbs Up http://www.gap-diagnostic.com/
Post #435379 Fri Sep 05 2014 10:54pm
PatGapInnov
Canada
Hi Guys
We've just released 2 new builds of firmware V3.0 for the IIDTool BT. The first one (release) now includes:
-The modified IPC firmware for earlier vehicles (clock on dash, no FBH light)
-Faster updating method for the IIDTool itself
The second one is a special build (1112) called Nav On Move. This firmware is used to enable destination entry while the vehicle is moving and cannot perform any diagnostic tasks. The process involve two consecutives reflashes of the Touchscreen and takes about 71 minutes. Please consult the IIDTool’s user manual for more details
Cheers http://www.gap-diagnostic.com/
Post #435825 Tue Sep 09 2014 9:36pm
jeffhunt
Kid tool bluetooth
Hi all.
I am looking to get a diagnostic tool to allow me to edit the ccf RRS 2011 TDV6. I need to make changes for TowBar, park heating and paddle change gears.
I saw in other posts that with the early IIDtool flashing the panel software to the 2012 version stopped the front parking sensors from working..... Does anyone know if this has been sorted?
Also, with the Bluetooth version, does this avoid the need to flash the console display screen as I quite like the look of the earlier version, I assume that all editing would be done by ipad or phone etc.
Definitely want to get one of these or something similar. Losing the front sensors would be a show stopper.
Any and all help greatly appreciated.
Thanks & have a good Christmas
Jeff
Post #445912 Sat Dec 20 2014 2:46pm
PatGapInnov
Canada
Hi Jeff
This was resolved a while back so no need to update the cluster, you can leave it like it is.
You can still use the integrated interface (cruise control buttons, instrument cluster screen) although it works a lot quicker with the mobile Apps.
Merry Christmas http://www.gap-diagnostic.com/
Post #445941 Sat Dec 20 2014 8:24pm
jeffhunt
Hi PatGapInnov,
thanks for the response Very Happy , IIDTool now on order.
I appreciate you taking the time to reply.
Merry Christmas
Jeff
Post #445942 Sat Dec 20 2014 8:30pm
zaphod
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
I'm really interested in getting one of these to have a go at flashing and reading fault codes etc. However I'm a bit confused as to which version would be best for my situation.
I don't have an iPad or Android tablet (not a fan of either really) but would rather not have to fanny about using the buttons on the dash if a better option is available.
I do have a Microsoft Surface Pro 3. It's basically a tablet that runs a full version of Windows 8.1. It has both USB and Bluetooth connectivity... I assume I can still get all the features using the Windows software?
So... do I just get the standard version or the BT one? Is bluetooth even a connectivity option for use with the windows software? I'm not bothered by using a USB cable, just don't want to miss out on any features!
Post #454543 Tue Mar 03 2015 7:24pm
PatGapInnov
Canada
Hi
Unfortunately, a tablet PC running on windows 8 cannot be connected via Bluetooth to an IIDTool BT. Your only other option, if you do not want to use the integrated interface, would be to use a PC (your tablet might work) and USB cable to have access to the integrated interface replica software or controller. It is the same as using the cruise control buttons and instrument pack info screen but with 2 additional lines and 26 characters per lines.
Since we are concentrating our efforts on mobile App running on iOS and Android, the PC controller software is only used in specific cases and will not be enhanced to reflect the current mobile Apps.
A regular non BT IIDTool would be appropriate unless you are planning to buy one of the supported iOS or Android device in the future.
Best Regards http://www.gap-diagnostic.com/
Post #454556 Tue Mar 03 2015 8:36pm
zaphod
Thanks for the quick reply. So basically all the fancy screenshots of graphs and emailing of fault reports is only available when connected to an ipad/android tablet?
Will I still be able to backup configurations, personal suspension height settings etc and export fault reports to a file of some sort with the windows version at least?
Post #454636 Wed Mar 04 2015 1:23pm
Disco_Mikey
Or most mobile phones Thumbs Up
Post #454638 Wed Mar 04 2015 2:00pm
zaphod
I've got a Nokia Lumia 1520 (Windows phone) so I guess that counts me out on the phone front too! Rolling with laughter
Post #454639 Wed Mar 04 2015 2:03pm
PatGapInnov
Canada
My pleasure, and yes, iOS and Android only.
Will I still be able to backup configurations, Yes
personal suspension height settings etc Yes
and export fault reports to a file of some sort with the windows version at least? Not supported on the PC controller which is a replica of the integrated interface.
During the development phase, we had to decide which devices would be the most valuable asset for the IIDTool BT. Our conclusion were iOS and Android devices. Supporting every single platform would be a monumental task therefore we have to limit ourselves to the most popular (and simple to work on...) platforms.
Post #454654 Wed Mar 04 2015 5:27pm
zaphod
Thanks, I'll stick with the standard model - just one last thing if you don't mind, can you just confirm that this is the correct part number for my car: DA6403 ?
Post #454751 Thu Mar 05 2015 4:56pm
PatGapInnov
Canada
My pleasure! DA6403 is indeed a regular non Bluetooth IIDTool for Range Rover Sport - 2005 - 2009 http://www.gap-diagnostic.com/
Post #454754 Thu Mar 05 2015 5:32pm
Page 3 of 4 <1234>
