Home > Tips & Tricks > Cleaning Side Steps
Rob_h
coca cola ?
http://youtu.be/wwoW1vBMzZs
Post #454505 Tue Mar 03 2015 2:03pm
Blueskye1
Wales 2008 Range Rover Sport TDV6 HSE Java Black
Just finished cleaning step trim thanks for all the tips..
Used wifes oven pad & some wet & dry on the drivers side & Autosol Very Happy
These finishing touches make all the difference wheel arches next..
Enjoy your Sunday Thumbs Up
Andrew My first RRS HSE Purchased June 2016
Java Black 2.7
Date of first registration 22 February 2008
Cousin of the King of Stamford Bridge R.I.P. Ossie
Post #507398 Sun Oct 09 2016 11:58am
It's also worth checking the undersides of these trims too, they seem to suffer an immense amount of corrosion with the trims dropping off after as little as a couple of years. I know our own Ady on here suffered with that and I know for a fact he looked after his RRS very well.
I wonder if coating with an underseal would be a good idea Confused ON THE WAY: BMW F21 M140i
Post #507518 Mon Oct 10 2016 4:02pm
Blueskye1
Thanks Beancounter Thumbs Up
Looking at my pics thinking about using Meguiars All Season on the rubber & plastic trim's anybody tried Question i read some good reviews on line.
Ref side step trim I did cost with poor boys sealant while I was doing the alloys
Java Black 2.7
Post #507521 Mon Oct 10 2016 4:14pm
If you want to do the job once and properly, get some Gtechniq C4, apply and forget. Really is the best and most durable plastic coating product out there. Costs more in the short term, but the results are superb. Thumbs Up
You can also use on the pillars (if plastic) and panel under the widescreen, all of which are prone to fading. Smile ON THE WAY: BMW F21 M140i
Post #507522 Mon Oct 10 2016 4:33pm
RRS ADDY
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bourneville
Diluted Acid I find it brings them up like brand new, had a disco 3 and used the same then👌
Post #577897 Tue Mar 26 2019 7:01pm
